Otherwise, you should be able to make an IF can from an old car radio work adequately- these often were 262 Khz, but they might tune close enough for your application.
If you have not opened up either can, you might want to take a look and see what is there- it may just be a broken lead right at the termination point. If you need to unwind a few turns, or if you need to add a short length, you can still make the old ones work. The only time tehy will not, is if the broken section is inside of the windings.
You may also want to consider re-winding the originals too. Just take meticulous notes, and pictures before you start so you know where connectons were, how they were routed, which direction they were wound, and spacing, as well as number of turns.
Radio Junkyard may also have a chassis with a similar IF resonance.
http://vintage-electronics.com/rjy.htm
MAJESTIC 460 2ND I F 175 K.C. IS OPEN ..BOTH SIDES..NEED A GENERIC I.F. CAN
: OR SUCH!!THIS FEEDS THE DETECTOR..BUT I CAN FAKE THE AVC AND USE ANY THING...HELP!!
: Hi,
: You can actually try one of the "universal" replacements, such as N.O.S. Millen, Miesner, etc.
: Otherwise, you should be able to make an IF can from an old car radio work adequately- these often were 262 Khz, but they might tune close enough for your application.
: If you have not opened up either can, you might want to take a look and see what is there- it may just be a broken lead right at the termination point. If you need to unwind a few turns, or if you need to add a short length, you can still make the old ones work. The only time tehy will not, is if the broken section is inside of the windings.
: You may also want to consider re-winding the originals too. Just take meticulous notes, and pictures before you start so you know where connectons were, how they were routed, which direction they were wound, and spacing, as well as number of turns.
: Radio Junkyard may also have a chassis with a similar IF resonance.
: http://vintage-electronics.com/rjy.htm
: MAJESTIC 460 2ND I F 175 K.C. IS OPEN ..BOTH SIDES..NEED A GENERIC I.F. CAN
: : OR SUCH!!THIS FEEDS THE DETECTOR..BUT I CAN FAKE THE AVC AND USE ANY THING...HELP!!
