Is there such a thing as filament sag. It was mentioned in an article about modifying a tube tester by mounts sockets in the side of the case so the tube would be horizontal when testing.
Does tube orientation matter alot? Should they always be vertical or can they be horizontal or upside down?
Thanks.
Mike M.
:Hi,
:Is there such a thing as filament sag. It was mentioned in an article about modifying a tube tester by mounts sockets in the side of the case so the tube would be horizontal when testing.
:Does tube orientation matter alot? Should they always be vertical or can they be horizontal or upside down?
:Thanks.
:Mike M.
Tube manuals will usually note the preferred mounting.
Here's info for a #80 tube:
http://www.nj7p.org/Tube4.php?tube=80
Carl T
I can visualize directly heated cathode filaments sag. But not indirectly heated cathodes.
Doug
:Hi,
:Thanks.
:Mike M.
