Thanks for your help!
This is basically an emissions checker. Jackson called it "dynamic," but it doesn't measure transconductance.
If you are wanting to match tubes, you may not need a tube tester. Except for push-pull amps, tubes really don't need to be matched. For push-pull stages, you can use some hi-fi audio amps, with adjustable bias, to match tubes. More info here: http://www.enginova.com/Tube_matching.htm
Doug
:Hi, il would like to know if this tube tester is a good thing. Can I match tube with this tester? If I remember, I need to check mutual conductance Gm (micromho) to do this? What is a good price for this?
:Thanks for your help!
