How 'bout a clue as to what kind of radio?
But, I'm wondering - do you have the Nash that goes with that radio?
Doug
:1951 Nash NH1C positive ground. Uses 6X4, 6AS5, 6AV6, 6BA6, and 6BE6. Thanks
The 12 volt Nash Metropolitan (PYE made in England) is quite similar to the Nash radio.
Meade
:Where does the loose wire go? It fell off when I pulled one side of the chassis a bit more than I should have. I can see no point where it connected. Positive ground thru the chassis so the negative must go to pins 3 or 4 of the 6 Volt tubes. Would this line go to pin 3 or 4 of the 6X4?
