Zenith 7s657r Alignment Instructions
6/4/2008 11:16:05 PMnom
6/4/2008 11:18:47 PMnom
Does anyone know how to find alignment instructions for a Zenith 7S657R? I can't find them on riders or beitmans.
Neal
6/4/2008 11:41:53 PMNorm Leal
Hi Neal
Zenith alignemnt information isn't with each schematic in Rider. Need to find another model which includes alignment data. See if this one works?
http://www.nostalgiaair.org/PagesByModel/384/M0025384.pdf
:Does anyone know how to find alignment instructions for a Zenith 7S657R? I can't find them on riders or beitmans.
:Neal
6/5/2008 12:28:53 AMnom
HI Norm,
I just finished restoring a 7S682. I have alingment instructions for that. The two sets are indeed very similiar. Just a few different tubes on the power end. The only difference I notice right away is the 7S657R has an additional 'N' trimmer.
My capacitors should be here tomorrow. I haven't had any luck in finding some light bulb protection for the power transformer. I've been looking for a bulb with a socket that I can mount. It's been hard to find a bulb that has a 300 volt rating, let alone the mounting part. I dropped my fuse rating to 3/4 of an amp.
It will be nice to hear this thing purr like a kitten, and I know it's going to sooner or later. Especially with good help...Neal
:Hi Neal
: Zenith alignemnt information isn't with each schematic in Rider. Need to find another model which includes alignment data. See if this one works?
:http://www.nostalgiaair.org/PagesByModel/384/M0025384.pdf
::Does anyone know how to find alignment instructions for a Zenith 7S657R? I can't find them on riders or beitmans.
::Neal
6/5/2008 9:54:56 AMNorm Leal
Hi Neal
Years ago they used #47 lamps in series with transformer high voltage leads. These bulbs are rated .15 amps. Much lower than your .75 amp fuse. 1/4 amp slo-blo fuses were popular in back and white TV's. Anything is better than nothing.
:HI Norm,
:I just finished restoring a 7S682. I have alingment instructions for that. The two sets are indeed very similiar. Just a few different tubes on the power end. The only difference I notice right away is the 7S657R has an additional 'N' trimmer.
:My capacitors should be here tomorrow. I haven't had any luck in finding some light bulb protection for the power transformer. I've been looking for a bulb with a socket that I can mount. It's been hard to find a bulb that has a 300 volt rating, let alone the mounting part. I dropped my fuse rating to 3/4 of an amp.
:It will be nice to hear this thing purr like a kitten, and I know it's going to sooner or later. Especially with good help...Neal
::Hi Neal
:: Zenith alignemnt information isn't with each schematic in Rider. Need to find another model which includes alignment data. See if this one works?
::http://www.nostalgiaair.org/PagesByModel/384/M0025384.pdf
:::Does anyone know how to find alignment instructions for a Zenith 7S657R? I can't find them on riders or beitmans.
:::Neal
6/6/2008 12:46:26 AMnom
Hi Norm,
I'll get a 150ma to 250ma bulb soldered in there on the two end leads somehow before I fire it up. Good advice sometimes falls on deaf ears, but not this time. Right now I'm putting the electrolytics in. What about the voltage rating? I don't know what a #47 lamp is rated at. I wouldn't imagine that it has any leads or sockets with it? Should I just solder to the case and the end pin? Just wondering out loud...Neal
:Hi Neal
: Years ago they used #47 lamps in series with transformer high voltage leads. These bulbs are rated .15 amps. Much lower than your .75 amp fuse. 1/4 amp slo-blo fuses were popular in back and white TV's. Anything is better than nothing.
::HI Norm,
::I just finished restoring a 7S682. I have alingment instructions for that. The two sets are indeed very similiar. Just a few different tubes on the power end. The only difference I notice right away is the 7S657R has an additional 'N' trimmer.
::My capacitors should be here tomorrow. I haven't had any luck in finding some light bulb protection for the power transformer. I've been looking for a bulb with a socket that I can mount. It's been hard to find a bulb that has a 300 volt rating, let alone the mounting part. I dropped my fuse rating to 3/4 of an amp.
::It will be nice to hear this thing purr like a kitten, and I know it's going to sooner or later. Especially with good help...Neal
:::Hi Neal
::: Zenith alignemnt information isn't with each schematic in Rider. Need to find another model which includes alignment data. See if this one works?
:::http://www.nostalgiaair.org/PagesByModel/384/M0025384.pdf
::::Does anyone know how to find alignment instructions for a Zenith 7S657R? I can't find them on riders or beitmans.
::::Neal
6/6/2008 5:46:31 PMSteve - W9DX
Neal: alignment procedures & socket voltage chart for your Zenith 7S657R have been e-mailed to you.
Good luck,
Steve - W9DX
6/6/2008 6:35:13 PMnom
:Neal: alignment procedures & socket voltage chart for your Zenith 7S657R have been e-mailed to you.
:Good luck,
:Steve - W9DX
THANK YOU Steve
:Good luck,
:Steve - W9DX
THANK YOU Steve
