European to U.S conversion
5/29/2008 2:28:46 PMMark
Hey guys!
Just purchased a telefunken set.
The cord was spliced with an U.S. two-pronged extension cord wire.
I believe this set had the European 3-prong plug.
When I test the two prongs with my meter I get no reading.
When I test the original wire from the set I get a reading.
How should this set be wired for U.S. use.
Thanks!
Mark
5/30/2008 12:02:31 PMDoug Criner
Mark: Does the set have a switch to select between 120V (US) or 220V (Europe)? Otherwise, you may need a step-up xfmr.
Doug
:Hey guys!
:Just purchased a telefunken set.
:The cord was spliced with an U.S. two-pronged extension cord wire.
:I believe this set had the European 3-prong plug.
:When I test the two prongs with my meter I get no reading.
:When I test the original wire from the set I get a reading.
:How should this set be wired for U.S. use.
:Thanks!
:Mark
5/30/2008 12:51:40 PMLewis Linson
I think the Germans use the PAL format, and the US uses the NTSC format, based on 50 Hz power. Something you might check on.
:Mark: Does the set have a switch to select between 120V (US) or 220V (Europe)? Otherwise, you may need a step-up xfmr.
:Doug
::Hey guys!
::Just purchased a telefunken set.
::The cord was spliced with an U.S. two-pronged extension cord wire.
::I believe this set had the European 3-prong plug.
::When I test the two prongs with my meter I get no reading.
::When I test the original wire from the set I get a reading.
::How should this set be wired for U.S. use.
::Thanks!
::Mark
5/30/2008 2:08:14 PMThomas Dermody
Is this a television or a radio? PAL and NTSC only have to do with color television, not radios.
5/30/2008 2:39:36 PMLewis Linson
:Is this a television or a radio? PAL and NTSC only have to do with color television, not radios.
:T.
I shouldn't post with only one cup of coffee. He wrote Telefunken, and I read Television. Disregard me.
5/31/2008 1:01:42 AMThomas Dermody
:D
5/30/2008 2:17:13 PMMArk
Hi again!
This se is a Telfunken D668 WK trop.
Well I figured ou the problem. It was the spliced in cord.
I attached a newer cord, plugged in the set and she came to life.
To my dimay she has a loud hum.
I suspect I have a bad power supply cap.
By the way this a european electrolytic cap.
Here is the data that appears on the can.
50+ 50uf 350/385
clf 50+50/350.
Should I gut this can and stuff with new caps or are replacement avalible?
Thanks!
Mark
PS: This set has a dial attached to the back of the chassi where you can adjust the voltage.
5/30/2008 2:25:15 PMDoug Criner
Mark: my style would be to disconnect the can caps and hang individual replacements under the chassis - leaving the cans there for ornamentation.
AES and RadioDaze sell can caps, but not sure if their mounting would be compatible?
Doug
:Hi again!
:This se is a Telfunken D668 WK trop.
:Well I figured ou the problem. It was the spliced in cord.
:I attached a newer cord, plugged in the set and she came to life.
:To my dimay she has a loud hum.
:I suspect I have a bad power supply cap.
:By the way this a european electrolytic cap.
:Here is the data that appears on the can.
:50+ 50uf 350/385
:clf 50+50/350.
:Should I gut this can and stuff with new caps or are replacement avalible?
:Thanks!
:Mark
:PS: This set has a dial attached to the back of the chassi where you can adjust the voltage.
