Tuning Eye on RCA T 60 and high voltage
5/24/2008 1:56:53 PMRon
I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
Ron
5/24/2008 2:00:31 PMLewis Linson
Ron:
By "not working", does that mean is not glowing, or is glowing and not closing on stations?
:Ron
5/24/2008 2:12:13 PMRon
Lewis,
It is not glowing at all except you can faintly see the filiments lit up.
Ron
:Ron:
:By "not working", does that mean is not glowing, or is glowing and not closing on stations?
:Lewis
:I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
::Ron
5/24/2008 2:25:44 PMRadiodoc
Ron,
Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
:Lewis,
:It is not glowing at all except you can faintly see the filiments lit up.
:Ron
::Ron:
::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
::Lewis
::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
:::Ron
5/24/2008 2:39:44 PMRon
If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
:Ron,
:Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
:Radiodoc
::Lewis,
::It is not glowing at all except you can faintly see the filiments lit up.
::Ron
:::Ron:
:::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
:::Lewis
:::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
::::Ron
5/24/2008 3:35:08 PMLewis Linson
Ron:
The tuniing eye socket is different in that there is a one meg. resistor between pins 2 and 4. Usually, this resistor is inside the socket. Old high value resistors like that often go bad with age. I haven't worked on a tuning eye radio in years, but someone can tell you how to get into the socket, change the resistor, and fix your radio.
:If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
::Ron,
::Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
::Radiodoc
:::Lewis,
:::It is not glowing at all except you can faintly see the filiments lit up.
:::Ron
::::Ron:
::::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
::::Lewis
::::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
:::::Ron
5/24/2008 5:16:02 PMIan
Sometimes if the filter cap value is to high the eye tube won't glow green, but the filiment will still light.
:Ron:
:The tuniing eye socket is different in that there is a one meg. resistor between pins 2 and 4. Usually, this resistor is inside the socket. Old high value resistors like that often go bad with age. I haven't worked on a tuning eye radio in years, but someone can tell you how to get into the socket, change the resistor, and fix your radio.
:Lewis
::If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
:::Ron,
:::Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
:::Radiodoc
::::Lewis,
::::It is not glowing at all except you can faintly see the filiments lit up.
::::Ron
:::::Ron:
:::::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
:::::Lewis
:::::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
::::::Ron
5/24/2008 5:59:58 PMRon
The schematic called for a 10uf, but all I had were 12uf. Would that small amount cause the problem?
:Sometimes if the filter cap value is to high the eye tube won't glow green, but the filiment will still light.
::Ron:
::The tuniing eye socket is different in that there is a one meg. resistor between pins 2 and 4. Usually, this resistor is inside the socket. Old high value resistors like that often go bad with age. I haven't worked on a tuning eye radio in years, but someone can tell you how to get into the socket, change the resistor, and fix your radio.
::Lewis
:::If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
::::Ron,
::::Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
::::Radiodoc
:::::Lewis,
:::::It is not glowing at all except you can faintly see the filiments lit up.
:::::Ron
::::::Ron:
::::::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
::::::Lewis
::::::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
:::::::Ron
5/24/2008 6:15:59 PMWade Epler
Ron, are you sure the tube isn't just worn out? The green phosphor material can wear out and fade to nothing if it has seen heavy use. Try running the radio in the dark, and you may see the tuning eye light weakly if this is the case. Btw, the 12uf cap should be fine to use in place of the 10uf...
wade
:The schematic called for a 10uf, but all I had were 12uf. Would that small amount cause the problem?
::Sometimes if the filter cap value is to high the eye tube won't glow green, but the filiment will still light.
:::Ron:
:::The tuniing eye socket is different in that there is a one meg. resistor between pins 2 and 4. Usually, this resistor is inside the socket. Old high value resistors like that often go bad with age. I haven't worked on a tuning eye radio in years, but someone can tell you how to get into the socket, change the resistor, and fix your radio.
:::Lewis
::::If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
:::::Ron,
:::::Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
:::::Radiodoc
::::::Lewis,
::::::It is not glowing at all except you can faintly see the filiments lit up.
::::::Ron
:::::::Ron:
:::::::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
:::::::Lewis
:::::::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
::::::::Ron
5/24/2008 6:44:11 PMRon
Wade,
I have tried one other tube from another radio, but it is one that I have not restored it yet so I am not positive it is good. I am going to replace the 1 meg resistor in the socket, the original is measuring at 1.6 meg. At that point I may order a replacement tube. Thanks for the help!
:Ron, are you sure the tube isn't just worn out? The green phosphor material can wear out and fade to nothing if it has seen heavy use. Try running the radio in the dark, and you may see the tuning eye light weakly if this is the case. Btw, the 12uf cap should be fine to use in place of the 10uf...
:wade
::The schematic called for a 10uf, but all I had were 12uf. Would that small amount cause the problem?
:::Sometimes if the filter cap value is to high the eye tube won't glow green, but the filiment will still light.
::::Ron:
::::The tuniing eye socket is different in that there is a one meg. resistor between pins 2 and 4. Usually, this resistor is inside the socket. Old high value resistors like that often go bad with age. I haven't worked on a tuning eye radio in years, but someone can tell you how to get into the socket, change the resistor, and fix your radio.
::::Lewis
:::::If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
::::::Ron,
::::::Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
::::::Radiodoc
:::::::Lewis,
:::::::It is not glowing at all except you can faintly see the filiments lit up.
:::::::Ron
::::::::Ron:
::::::::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
::::::::Lewis
::::::::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
:::::::::Ron
5/24/2008 6:45:53 PMLewis Linson
Why, with all the info we have here at our hands, find another radeo similar to yours that has a Voltage chart for the pins, and check your 1 meg. resistor that way?
:wade
::::Ron:
::::Lewis
::::::Ron,
::::::Radiodoc
:::::::Lewis,
:::::::Ron
::::::::Ron:
::::::::Lewis
:::::::::Ron
5/24/2008 9:11:26 PMLewis Linson
Ron:
You said you tested that tube. Did you ever see it glow green, or did you just read the triode quality?
:Why, with all the info we have here at our hands, find another radeo similar to yours that has a Voltage chart for the pins, and check your 1 meg. resistor that way?
:Lewis
::Ron, are you sure the tube isn't just worn out? The green phosphor material can wear out and fade to nothing if it has seen heavy use. Try running the radio in the dark, and you may see the tuning eye light weakly if this is the case. Btw, the 12uf cap should be fine to use in place of the 10uf...
::wade
:::The schematic called for a 10uf, but all I had were 12uf. Would that small amount cause the problem?
::::Sometimes if the filter cap value is to high the eye tube won't glow green, but the filiment will still light.
:::::Ron:
:::::The tuniing eye socket is different in that there is a one meg. resistor between pins 2 and 4. Usually, this resistor is inside the socket. Old high value resistors like that often go bad with age. I haven't worked on a tuning eye radio in years, but someone can tell you how to get into the socket, change the resistor, and fix your radio.
:::::Lewis
::::::If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
:::::::Ron,
:::::::Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
:::::::Radiodoc
::::::::Lewis,
::::::::It is not glowing at all except you can faintly see the filiments lit up.
::::::::Ron
:::::::::Ron:
:::::::::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
:::::::::Lewis
:::::::::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
::::::::::Ron
5/24/2008 10:12:46 PMRon
The new 1 meg resistor did it! It does not glow real bright, but it definitely is responding to the station coming in stronger. Thanks everyone for the help, this was a great learning experience!
Ron
:Ron:
:You said you tested that tube. Did you ever see it glow green, or did you just read the triode quality?
:Lewis
::Why, with all the info we have here at our hands, find another radeo similar to yours that has a Voltage chart for the pins, and check your 1 meg. resistor that way?
::Lewis
:::Ron, are you sure the tube isn't just worn out? The green phosphor material can wear out and fade to nothing if it has seen heavy use. Try running the radio in the dark, and you may see the tuning eye light weakly if this is the case. Btw, the 12uf cap should be fine to use in place of the 10uf...
:::wade
::::The schematic called for a 10uf, but all I had were 12uf. Would that small amount cause the problem?
:::::Sometimes if the filter cap value is to high the eye tube won't glow green, but the filiment will still light.
::::::Ron:
::::::The tuniing eye socket is different in that there is a one meg. resistor between pins 2 and 4. Usually, this resistor is inside the socket. Old high value resistors like that often go bad with age. I haven't worked on a tuning eye radio in years, but someone can tell you how to get into the socket, change the resistor, and fix your radio.
::::::Lewis
:::::::If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
::::::::Ron,
::::::::Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
::::::::Radiodoc
:::::::::Lewis,
:::::::::It is not glowing at all except you can faintly see the filiments lit up.
:::::::::Ron
::::::::::Ron:
::::::::::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
::::::::::Lewis
::::::::::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
:::::::::::Ron
5/25/2008 12:18:12 PMNorm Leal
Hi Ron
All that's required for an eye tube to show green are filament lit, cathode grounded and around 250 volts on target, pin #4. Tubes lose their green glow after some use.
The 1 meg resistor between pin #2 and #4 has to be good to get eye movement but does not control amount of green. You may be seeing green only at the tuning wedge?
http://antiqueradios.com/chrs/journal/eyetube.html
:The new 1 meg resistor did it! It does not glow real bright, but it definitely is responding to the station coming in stronger. Thanks everyone for the help, this was a great learning experience!
:Ron
::Ron:
::You said you tested that tube. Did you ever see it glow green, or did you just read the triode quality?
::Lewis
:::Why, with all the info we have here at our hands, find another radeo similar to yours that has a Voltage chart for the pins, and check your 1 meg. resistor that way?
:::Lewis
::::Ron, are you sure the tube isn't just worn out? The green phosphor material can wear out and fade to nothing if it has seen heavy use. Try running the radio in the dark, and you may see the tuning eye light weakly if this is the case. Btw, the 12uf cap should be fine to use in place of the 10uf...
::::wade
:::::The schematic called for a 10uf, but all I had were 12uf. Would that small amount cause the problem?
::::::Sometimes if the filter cap value is to high the eye tube won't glow green, but the filiment will still light.
:::::::Ron:
:::::::The tuniing eye socket is different in that there is a one meg. resistor between pins 2 and 4. Usually, this resistor is inside the socket. Old high value resistors like that often go bad with age. I haven't worked on a tuning eye radio in years, but someone can tell you how to get into the socket, change the resistor, and fix your radio.
:::::::Lewis
::::::::If I am numbering the pins correctly, pin 2 has 15 volts and pin 4 has 250. I say if I am numbering them correctly because it seems like I am numbering the opposite of what I normally do under the radio. I started at the dot and number one was counter clockwise. If I do it the otherway I get no readings. Is there something different about a tuning eye socket. Thanks for the help.
:::::::::Ron,
:::::::::Check the B+ voltage at pins 2 and 4 of the 6U5 socket. On pin 4 it should be around 270 volts according to the schematic.
:::::::::Radiodoc
::::::::::Lewis,
::::::::::It is not glowing at all except you can faintly see the filiments lit up.
::::::::::Ron
:::::::::::Ron:
:::::::::::By "not working", does that mean is not glowing, or is glowing and not closing on stations?
:::::::::::Lewis
:::::::::::I am having trouble discovering why the tuning eye of a RCA T 60 is not working. I have recapped checked all the resistors and they are in tolerance. The radio plays and seems to pick up stations ok. I checked voltages and discovered that Pin 4 of 6SA7 and pin 6 of the 6Sk7 are at 89 volts, but the schematic has them at 36 volts. I am using a Heathkit VTVM for measurements. I believe I checked the AVC because I measured the negative voltage increase on the gid of the 6SQ7 when I tuned in a stronger station. I am at a loss of what to check next. One more thing I checked the 6U5 tube at it seemed to check out ok. The filiments of the 6U5 do light up when the set is turned on. Thanks for any help.
::::::::::::Ron
