6SS7 vs 12SK7
5/22/2008 6:53:18 PMPeter G. Balazsy
I'm currently working on a Farnsworth ET-066 that employs the use of 6 tubes total.
6SS7, 12SA7, 6SS7, 12SQ7, 50L6, 35Z5.
The 6SS7 seems to be almost the same as a 12SK7 so I wonder why the 6SS7 was used?
To keep the filament totals the same... many other six-tube sets of that same generation, used two 12SK7s and a 35L6 for the output tube instead of the 50L6.
Does anyone know a good reason for Farnsworth using the 6SS7 over the 12SK7?
... or was it because one was available before the other was introduced?
5/23/2008 10:47:54 AMNorm Leal
Hi Peter
I mentiond this on ARF. The 6SS7 was used where 6 tubes had filaments wired in series. If 12SK7 were in the circuit voltage drop would exceed line voltage. With high line voltage using 2 - 12SK7 would be a good idea. Tubes have the same basing.
They could have used a 35L6 but output is rated slightly lower.
Since 6SS7 is a low power filament tube would have also been used in battery radios.
:I'm currently working on a Farnsworth ET-066 that employs the use of 6 tubes total.
: 6SS7, 12SA7, 6SS7, 12SQ7, 50L6, 35Z5.
:The 6SS7 seems to be almost the same as a 12SK7 so I wonder why the 6SS7 was used?
:To keep the filament totals the same... many other six-tube sets of that same generation, used two 12SK7s and a 35L6 for the output tube instead of the 50L6.
:Does anyone know a good reason for Farnsworth using the 6SS7 over the 12SK7?
:... or was it because one was available before the other was introduced?
5/23/2008 1:07:59 PMBill G.
:Hi Peter
: I mentiond this on ARF. The 6SS7 was used where 6 tubes had filaments wired in series. If 12SK7 were in the circuit voltage drop would exceed line voltage. With high line voltage using 2 - 12SK7 would be a good idea. Tubes have the same basing.
: They could have used a 35L6 but output is rated slightly lower.
: Since 6SS7 is a low power filament tube would have also been used in battery radios.
::I'm currently working on a Farnsworth ET-066 that employs the use of 6 tubes total.
:: 6SS7, 12SA7, 6SS7, 12SQ7, 50L6, 35Z5.
::The 6SS7 seems to be almost the same as a 12SK7 so I wonder why the 6SS7 was used?
::To keep the filament totals the same... many other six-tube sets of that same generation, used two 12SK7s and a 35L6 for the output tube instead of the 50L6.
::Does anyone know a good reason for Farnsworth using the 6SS7 over the 12SK7?
::... or was it because one was available before the other was introduced?
Hi Norm and Peter,
I think the two 12SK7s and 36L6GT make for a better design, as it distributes the heat more evenly. 50L6GT gets hotter than 35L6GT.
I suspect that the 6SS7 was used because they had a lot of them or 50L6GT in stock to use up.
Best Regards,
Bill Grimm
5/23/2008 1:52:44 PMNorm Leal
Hi Bill
Agree with that. Using a 35L6 would distribute heat better but just about everyone used 50 volt tubes as output in AA5's. Philco used some 35 volt tubes for output along with a series resistor. Some of the lastest series wired radios did use lower voltage output tubes and 18 volt ones for RF & IF.
6BJ6 was also used this way in place of 12BA6.
How would a company have too many 6SS7's if they weren't used very often except in this type of circuit. Agree Philco had way too many #41's so continued to use them into the 1940's.
::Hi Peter
:: I mentiond this on ARF. The 6SS7 was used where 6 tubes had filaments wired in series. If 12SK7 were in the circuit voltage drop would exceed line voltage. With high line voltage using 2 - 12SK7 would be a good idea. Tubes have the same basing.
:: They could have used a 35L6 but output is rated slightly lower.
:: Since 6SS7 is a low power filament tube would have also been used in battery radios.
:::I'm currently working on a Farnsworth ET-066 that employs the use of 6 tubes total.
::: 6SS7, 12SA7, 6SS7, 12SQ7, 50L6, 35Z5.
:::The 6SS7 seems to be almost the same as a 12SK7 so I wonder why the 6SS7 was used?
:::To keep the filament totals the same... many other six-tube sets of that same generation, used two 12SK7s and a 35L6 for the output tube instead of the 50L6.
:::Does anyone know a good reason for Farnsworth using the 6SS7 over the 12SK7?
:::... or was it because one was available before the other was introduced?
:Hi Norm and Peter,
: I think the two 12SK7s and 36L6GT make for a better design, as it distributes the heat more evenly. 50L6GT gets hotter than 35L6GT.
: I suspect that the 6SS7 was used because they had a lot of them or 50L6GT in stock to use up.
:Best Regards,
:Bill Grimm
5/23/2008 11:26:54 PMThomas Dermody
35L6 was produced before the 50L6. It is likely that the manufacturer preferred the 50L6 to the 35L6, or perhaps had a huge stock of 50L6 tubes, since the 35L6 seemed to drop out of use. It does have a slight bit more power, though I can't really notice. 6SS7 definitely isn't a common tube.
If you want a definite increase in power and bass, use the 50C6G. I like it, and I like the G shape, too, though it takes up quite a bit more room than the GT tubes, and it looks out of place. If you can obtain a complete set of Zenith AA5 G style tubes, you'll be set to go. Just try not to eat up the 50C6G supply for me. I like them, too.
