Manual for UHER SG 561 Royal
10/27/2000 3:47:56 PMJoão Novais
I'd like to have the manual because my uncle left me this recorder in mint condition, but the all the legends are in german and I would like to connect to my home stereo properly because I have a lot of family tapes recorded by my parents of me and my brothers learning how to talk and playing.Can anyone help me? .
Thank you
10/27/2000 6:13:42 PMJohn McPherson
Does your recorder have a 5 pin "DIN" plug? If so, you can find these to convert to RCA (phono plugs).
If you currently have this, you can safely plug your leads in to the amp through "tape monitor" (be sure to press the button to switch this as an active input), or "auxillary input", or "Line input" one at a time to determine your output of the deck, as well as your tape inputs to plug into your "line out" (on the deck) connections. Your "line in" connections will not produce an output when plugged into an input. SInce you are working with "tape monitor", or "line in" on the amp, you are not going to damage anything.
Otherwise, look in the manual to see what is labelled "Ertrag"- output. "Eingebe" or "Eingeben" is input.
Left should be "linkshandig" (I am missing umlauts, and may have the conjugation wrong)
Right should be "Rechtshandig" (also missing umlauts)
: I'd like to have the manual because my uncle left me this recorder in mint condition, but the all the legends are in german and I would like to connect to my home stereo properly because I have a lot of family tapes recorded by my parents of me and my brothers learning how to talk and playing.Can anyone help me? .
: Thank you
12/13/2000 8:22:40 AMCarsten Peters
Hi, i have a Manual for a Uher Variocord 263, but the connectors are nearly the same ones as the royal connectors. It is easy to connect a German Din-Pin to a Cinch Pin. If you want to, i scan the Pictures, translate them into english, and send them via Email.
Best regards from Germany
Carsten
10/29/2000 7:28:30 AMDon Black
Hi João,
Try German Wumpus Radio at http://www.oldradios.de/ You can get a free German to English dictionary of radio terms there that might help you understand the labels on your tape recorder. They might also have the manual for sale too. Make sure it's in English or you'll have to get it translated. Altavista search engine site has a German to English translator you can use online. It's not perfect but uaually can help you understand the German meaning. Hope this helps, Don Black.
: Thank you
