Neal
:I've got to replace this burnt up part and I can't tell for sure what it is. It has axial leads. It's elongated like a resistor. It has metal caps on each end with a color coded dot on it. It's body is covered with wire mesh. Inside it has white powder and what looks like a wire in the center going from end to end. Any ideas?
:Neal
Neal
What does each end connect to?
:Then compare to schematic and then check parts list.
According to Rider's schematic, R-1 is a 52 ohm wirewound resistor. It connects from ground to a common tie point with resistor R-2. The parts list, however does not indicate that R-2 is a wirewound resistor.
I hope this helps some.
Doug
:Well, is it just a power resistor?
::I've got to replace this burnt up part and I can't tell for sure what it is. It has axial leads. It's elongated like a resistor. It has metal caps on each end with a color coded dot on it. It's body is covered with wire mesh. Inside it has white powder and what looks like a wire in the center going from end to end. Any ideas?
::Neal
:::I've got to replace this burnt up part and I can't tell for sure what it is. It has axial leads. It's elongated like a resistor. It has metal caps on each end with a color coded dot on it. It's body is covered with wire mesh. Inside it has white powder and what looks like a wire in the center going from end to end. Any ideas?
:::Neal
:::Neal
