Regards,
Gene
HP did make diodes but I don't find your number. The good thing being diodes are interchangeable. If a detector, germanium will work. If power supply, high voltage silicon. As a zener you would need the regulating voltage. Where is the diode in your circuit? Knowing that, maybe someone can help.
: I'm looking for a source of obselete semiconductors. I'm sure many of us have the problem, sooner or later.
: I need to find a HPA 2034 diode. I've heard that it was made by Hewlett Packard. I doubt that, because as far as I know, they never made (or sourced) semiconductors. I need other semiconductors for a Model 18 Marantz. Anyone found any sources? It's gotten to the point where it's easy to fix tube equipment, but try vintage transistor equipment, good luck
: Regards,
: Gene
: HP did make diodes but I don't find your number. The good thing being diodes are interchangeable. If a detector, germanium will work. If power supply, high voltage silicon. As a zener you would need the regulating voltage. Where is the diode in your circuit? Knowing that, maybe someone can help.
: Norm
: : I'm looking for a source of obselete semiconductors. I'm sure many of us have the problem, sooner or later.
: : I need to find a HPA 2034 diode. I've heard that it was made by Hewlett Packard. I doubt that, because as far as I know, they never made (or sourced) semiconductors. I need other semiconductors for a Model 18 Marantz. Anyone found any sources? It's gotten to the point where it's easy to fix tube equipment, but try vintage transistor equipment, good luck
: : Regards,
: : Gene
Norm:
This diode is a detector in a Marantz 10B. I've been told that nothing but the original diode will do properly, (Otherwise it will need a re-align), I would prefer using the original, (Or a exact replacement)
Regards,
Gene Lambert
If it is a quadrature detector, it makes zero difference, just make sure to replace all four diodes. If it is a ratio detector, you still have a bit of lattitude, if tuning is at all affected here, it will have more impact on your channel sepration, than it will on the actual dial. Most people would never notice a difference, and those who claim to hear the difference between .01THD, and .1THD can be disregarded. (as a general rule). In seriousness, any reciever with any age, or any amount of handling will be out of alignment.
If you want to be precise about it, you can retune the whole unit, it is not as daunting as it sounds, as you would be peaking your IF transformers, calibrating your tuning dial to track correctly, and centering that last stage for maximum channel seperation (19Khz). You can sometimes do an adequate job tuning by ear, but you need to have a really good ear to start.
If it were me- do the swap, you can always change them out later- and see if you can hear adequate channel seperation on a familiar piece of classical music (Ina Godda Davida does not count as classical), More than likely you will hear more than adequate seperation.
: : Hi Gene
: : HP did make diodes but I don't find your number. The good thing being diodes are interchangeable. If a detector, germanium will work. If power supply, high voltage silicon. As a zener you would need the regulating voltage. Where is the diode in your circuit? Knowing that, maybe someone can help.
: : Norm
: : : I'm looking for a source of obselete semiconductors. I'm sure many of us have the problem, sooner or later.
: : : I need to find a HPA 2034 diode. I've heard that it was made by Hewlett Packard. I doubt that, because as far as I know, they never made (or sourced) semiconductors. I need other semiconductors for a Model 18 Marantz. Anyone found any sources? It's gotten to the point where it's easy to fix tube equipment, but try vintage transistor equipment, good luck
: : : Regards,
: : : Gene
: Norm:
: This diode is a detector in a Marantz 10B. I've been told that nothing but the original diode will do properly, (Otherwise it will need a re-align), I would prefer using the original, (Or a exact replacement)
: Regards,
: Gene Lambert
: If it is a quadrature detector, it makes zero difference, just make sure to replace all four diodes. If it is a ratio detector, you still have a bit of lattitude, if tuning is at all affected here, it will have more impact on your channel sepration, than it will on the actual dial. Most people would never notice a difference, and those who claim to hear the difference between .01THD, and .1THD can be disregarded. (as a general rule). In seriousness, any reciever with any age, or any amount of handling will be out of alignment.
: If you want to be precise about it, you can retune the whole unit, it is not as daunting as it sounds, as you would be peaking your IF transformers, calibrating your tuning dial to track correctly, and centering that last stage for maximum channel seperation (19Khz). You can sometimes do an adequate job tuning by ear, but you need to have a really good ear to start.
: If it were me- do the swap, you can always change them out later- and see if you can hear adequate channel seperation on a familiar piece of classical music (Ina Godda Davida does not count as classical), More than likely you will hear more than adequate seperation.
: : : Hi Gene
: : : HP did make diodes but I don't find your number. The good thing being diodes are interchangeable. If a detector, germanium will work. If power supply, high voltage silicon. As a zener you would need the regulating voltage. Where is the diode in your circuit? Knowing that, maybe someone can help.
: : : Norm
: : : : I'm looking for a source of obselete semiconductors. I'm sure many of us have the problem, sooner or later.
: : : : I need to find a HPA 2034 diode. I've heard that it was made by Hewlett Packard. I doubt that, because as far as I know, they never made (or sourced) semiconductors. I need other semiconductors for a Model 18 Marantz. Anyone found any sources? It's gotten to the point where it's easy to fix tube equipment, but try vintage transistor equipment, good luck
: : : : Regards,
: : : : Gene
: : Norm:
: : This diode is a detector in a Marantz 10B. I've been told that nothing but the original diode will do properly, (Otherwise it will need a re-align), I would prefer using the original, (Or a exact replacement)
: : Regards,
: : Gene Lambert
Dean
By the way, as an interesting note, I'm told that hp's tunnel diode line was doing beautifully until one day, they began to have 0% yield, as though they no longer knew how to make tunnel diodes. After checking and rechecking their equipment and supplies, they found out that over that weekend, Palo Alto had begun floridating their water and it was affecting one of their processes. The story may be apocryphal, of course, but hey, it's kinda cute.
: Regards,
: Gene
: : Regards,
: : Gene
: : Regards,
: : Gene
HI
I HAVE BEEN TRYING TO FIND A CROSS TO A HEWLETT-PACKARD 8447A AMPLIFIER. THE TRANSISTOR #
IS 1884-0012.CAN YOU HELP ME ? I WOULD SURE GREATFUL FOR THE HELP.
MALENFANT ELECTRONICS
THANK YOU MUCH
