Zenith 7S682 k trimmer still cuts 18mc in and out
5/7/2008 11:41:39 AMnom
Hi...Does anyone have any ideas on why my SW signal cuts in and out when I'm trying to align it. I comes in fairly strong and then abruptly cuts out in about 3 different places. I want it to hone in on the signal solid and not have to worry about going off frequency when the set gets bumped a little.
I know it has to do with c5 and c2 and r7,8,9. They're all the proper values.
Neal
5/9/2008 11:32:47 AMnom
To all,
One last try for some input on this. I've got my console ready and I'll soon be putting it back together. If no one has any ideas on this I'll just live with it for now. Phonograph works too. I would like to eliminate the squeal on BC and Steady up the signal on SW, but you can only do so much I guess. I believe it was called a 1942 Zenith 'Beverly'.
:Hi...Does anyone have any ideas on why my SW signal cuts in and out when I'm trying to align it. I comes in fairly strong and then abruptly cuts out in about 3 different places. I want it to hone in on the signal solid and not have to worry about going off frequency when the set gets bumped a little.
:I know it has to do with c5 and c2 and r7,8,9. They're all the proper values.
:Neal
5/15/2008 11:43:12 PMNorm Leal
Hi Neal
I'll make some guesses. Does tuner plates short? Sometimes a strand of steel wool can do this. Does tuner have good ground contact? Some tuners have a ground wire from rotor to frame.
When it cuts out does the oscillator quit?
:To all,
:One last try for some input on this. I've got my console ready and I'll soon be putting it back together. If no one has any ideas on this I'll just live with it for now. Phonograph works too. I would like to eliminate the squeal on BC and Steady up the signal on SW, but you can only do so much I guess. I believe it was called a 1942 Zenith 'Beverly'.
::Hi...Does anyone have any ideas on why my SW signal cuts in and out when I'm trying to align it. I comes in fairly strong and then abruptly cuts out in about 3 different places. I want it to hone in on the signal solid and not have to worry about going off frequency when the set gets bumped a little.
::I know it has to do with c5 and c2 and r7,8,9. They're all the proper values.
::Neal
5/16/2008 12:30:18 AMnom
I had given up on any input on this, thank you Norm. I don't know if the tuner plates short or not. You can tune on past it. The tuner does have good ground contact. I've checked that. I've even removed the trimmer and filed where it makes contact with the chassis.
I don't know how to check if the oscillator stops. I am reading about -7.5vdc on the avc line and it immediately drops to about -1.5 (or should I say climbs). Then as I continue in the same direction I can experience it again 2 more times before bottoming out the trimmer.
I've pretty much decided to live with it for now. I have it mounted back in the console with the phonograph and I am just putting the finishing touches on it. (Decals, mounting bolts, wavemagnet, etc) Thanks again for your input. I have another post going on the one on the bench, a 7S657R Zenith.
Neal
Hi Neal
: I'll make some guesses. Does tuner plates short? Sometimes a strand of steel wool can do this. Does tuner have good ground contact? Some tuners have a ground wire from rotor to frame.
: When it cuts out does the oscillator quit?
::To all,
::One last try for some input on this. I've got my console ready and I'll soon be putting it back together. If no one has any ideas on this I'll just live with it for now. Phonograph works too. I would like to eliminate the squeal on BC and Steady up the signal on SW, but you can only do so much I guess. I believe it was called a 1942 Zenith 'Beverly'.
:::Hi...Does anyone have any ideas on why my SW signal cuts in and out when I'm trying to align it. I comes in fairly strong and then abruptly cuts out in about 3 different places. I want it to hone in on the signal solid and not have to worry about going off frequency when the set gets bumped a little.
:::I know it has to do with c5 and c2 and r7,8,9. They're all the proper values.
:::Neal
5/16/2008 9:50:38 AMRadiodoc
:I had given up on any input on this, thank you Norm. I don't know if the tuner plates short or not. You can tune on past it. The tuner does have good ground contact. I've checked that. I've even removed the trimmer and filed where it makes contact with the chassis.
:I don't know how to check if the oscillator stops. I am reading about -7.5vdc on the avc line and it immediately drops to about -1.5 (or should I say climbs). Then as I continue in the same direction I can experience it again 2 more times before bottoming out the trimmer.
:I've pretty much decided to live with it for now. I have it mounted back in the console with the phonograph and I am just putting the finishing touches on it. (Decals, mounting bolts, wavemagnet, etc) Thanks again for your input. I have another post going on the one on the bench, a 7S657R Zenith.
:Neal
:Hi Neal
:: I'll make some guesses. Does tuner plates short? Sometimes a strand of steel wool can do this. Does tuner have good ground contact? Some tuners have a ground wire from rotor to frame.
:: When it cuts out does the oscillator quit?
:::To all,
:::One last try for some input on this. I've got my console ready and I'll soon be putting it back together. If no one has any ideas on this I'll just live with it for now. Phonograph works too. I would like to eliminate the squeal on BC and Steady up the signal on SW, but you can only do so much I guess. I believe it was called a 1942 Zenith 'Beverly'.
::::Hi...Does anyone have any ideas on why my SW signal cuts in and out when I'm trying to align it. I comes in fairly strong and then abruptly cuts out in about 3 different places. I want it to hone in on the signal solid and not have to worry about going off frequency when the set gets bumped a little.
::::I know it has to do with c5 and c2 and r7,8,9. They're all the proper values.
::::Neal
5/16/2008 9:58:24 AMRadiodoc
Nom,
It would seem the K trimmer may be shorting as you adjust it. You may be able to measure across the trimmer with a VOM as you adjust it. You may have to disconnect one end of the trimmer to measure if a coil is across it. It is possible too that there is a bad connection in the construction of the trimmer. If it is mounted on a coil, the coil lead(s) at its solder lugs may not be making good contact and need to be resoldered. If the trimmer is mounted on a coil, it is possible moving or bumping the coil may cause the same symptom. In other words there could be something in that area that is loose.
:Neal
:Hi Neal
:::To all,
::::Neal
5/17/2008 1:20:59 AMnom
Radiodoc,
You have some good practical ideas there. I'll examine the trimmer the next time I have it out of the console.
Neal
:Nom,
:It would seem the K trimmer may be shorting as you adjust it. You may be able to measure across the trimmer with a VOM as you adjust it. You may have to disconnect one end of the trimmer to measure if a coil is across it. It is possible too that there is a bad connection in the construction of the trimmer. If it is mounted on a coil, the coil lead(s) at its solder lugs may not be making good contact and need to be resoldered. If the trimmer is mounted on a coil, it is possible moving or bumping the coil may cause the same symptom. In other words there could be something in that area that is loose.
:Radiodoc
::I had given up on any input on this, thank you Norm. I don't know if the tuner plates short or not. You can tune on past it. The tuner does have good ground contact. I've checked that. I've even removed the trimmer and filed where it makes contact with the chassis.
::I don't know how to check if the oscillator stops. I am reading about -7.5vdc on the avc line and it immediately drops to about -1.5 (or should I say climbs). Then as I continue in the same direction I can experience it again 2 more times before bottoming out the trimmer.
::I've pretty much decided to live with it for now. I have it mounted back in the console with the phonograph and I am just putting the finishing touches on it. (Decals, mounting bolts, wavemagnet, etc) Thanks again for your input. I have another post going on the one on the bench, a 7S657R Zenith.
::Neal
::Hi Neal
::: I'll make some guesses. Does tuner plates short? Sometimes a strand of steel wool can do this. Does tuner have good ground contact? Some tuners have a ground wire from rotor to frame.
::: When it cuts out does the oscillator quit?
::::To all,
::::One last try for some input on this. I've got my console ready and I'll soon be putting it back together. If no one has any ideas on this I'll just live with it for now. Phonograph works too. I would like to eliminate the squeal on BC and Steady up the signal on SW, but you can only do so much I guess. I believe it was called a 1942 Zenith 'Beverly'.
:::::Hi...Does anyone have any ideas on why my SW signal cuts in and out when I'm trying to align it. I comes in fairly strong and then abruptly cuts out in about 3 different places. I want it to hone in on the signal solid and not have to worry about going off frequency when the set gets bumped a little.
:::::I know it has to do with c5 and c2 and r7,8,9. They're all the proper values.
:::::Neal
