Fujitsu-Ten/Toyota
4/29/2008 8:37:32 PMMarv Nuce
Forum,
I have obtained an '04 Lexus AM/FM/CD/Cassette set as payment for reclaiming 4 favorite CD's lost in the mechanism. With both 12 volt wall and batt power available, thought it would make a nice GARAGE ENTERTAINMENT CENTER/TEST TOOL. It has a separate power amp/player, and need a cable diagram for the 4 connectors. Tried Googling the p/n with no success.
5/1/2008 5:06:01 AMWalt
Marv- What model 2004 Lexus? I too use a car radio as my workbench reference/entertainment radio. -Walt.
5/1/2008 12:06:07 PMMarv Nuce
Walt,
Thanks for the reply. Its a 2002 IS300
: Marv- What model 2004 Lexus? I too use a car radio as my workbench reference/entertainment radio. -Walt.
5/2/2008 6:21:19 PMEdd
That is not just your ordinary ray-dee-ooooh…looking at the wiring diagram the Navigational system shows to be hooked into the system also.
I see what they refer to the Radio- Player Section and the separate Stereo Component Amplifier section.
Now any chance that your radio DISPLAY portion is a plug in unit, that you have or possibly a removable faceplate, such is so popular on units now-a days.. Also… the unit shows digi-multiplexing interconnect lines….OR…shudder…the unit might be dependent upon call up shared display on the Navigation units display…which you no havee..
The unit shows 12 connections onto the radio-Player section and ~26 connections to the Stereo Component Amplifier section.
I was researching in on our collegiate Advanced Automotive Technology Divison, but it is geared towards output into video display units for quick referencing by instructors and students…therefore I could only print out and that was totally unsatisfactory, what with the fine numbering details resolution on print.
With absolutely no word processing programming installed on the units (Copyright mandates via the supplier) I can’t pull my magic in transporting files or any alliterations thereof..
Should you have access to ALLDATA at a collegiate source or MAJOR public library, you also might gain access to same.
In the interim fill us in on the display mode and if you also got the separate antenna amplifier module that was mounted over at the antenna proper ?
The unit shows to be feeding 8 speakers.
Initially fill me in on what you have, and if necessary, if I mag up the displays I can make out , and manually copy down all of the connector pin numbers assigned as well as the cablings wire color coding…(which should be of no consequence since you assuredly don’t have that.)
Standing by…
5/2/2008 8:04:24 PMMarv Nuce
EDD,
Thanks for taking an interest. Found out its an '02 Lexus IS300. Has a separate power amp (Toyota#86280-53050/Fujitsu#141001-82800101) w/2 multi pin connectors. A separate radio/player chassis (AM/FM/CD/Cassette Toyota#86120-53120/Fujitsu#122000-2781A101) w/2 multipin connectors. Presumably the ant amp was left in the car for the after market set. Walt sent me a 5 page .gif file, but can't read most of the text. No NAV system, and just small 4" x 3/4" LCD just above the cassette mouth. Obviously digi com between the amp and player. I could gin up some connector bodies fron hardwood and JB Weld and connector receptacle inserts w/brass/copper tubing.
:That is not just your ordinary ray-dee-ooooh…looking at the wiring diagram the Navigational system shows to be hooked into the system also.
:I see what they refer to the Radio- Player Section and the separate Stereo Component Amplifier section.
:Now any chance that your radio DISPLAY portion is a plug in unit, that you have or possibly a removable faceplate, such is so popular on units now-a days.. Also… the unit shows digi-multiplexing interconnect lines….OR…shudder…the unit might be dependent upon call up shared display on the Navigation units display…which you no havee..
:The unit shows 12 connections onto the radio-Player section and ~26 connections to the Stereo Component Amplifier section.
:I was researching in on our collegiate Advanced Automotive Technology Divison, but it is geared towards output into video display units for quick referencing by instructors and students…therefore I could only print out and that was totally unsatisfactory, what with the fine numbering details resolution on print.
:With absolutely no word processing programming installed on the units (Copyright mandates via the supplier) I can’t pull my magic in transporting files or any alliterations thereof..
:Should you have access to ALLDATA at a collegiate source or MAJOR public library, you also might gain access to same.
:In the interim fill us in on the display mode and if you also got the separate antenna amplifier module that was mounted over at the antenna proper ?
:The unit shows to be feeding 8 speakers.
:Initially fill me in on what you have, and if necessary, if I mag up the displays I can make out , and manually copy down all of the connector pin numbers assigned as well as the cablings wire color coding…(which should be of no consequence since you assuredly don’t have that.)
:Standing by…
5/2/2008 8:23:29 PMMarv Nuce
EDD,
No don't have collegiate access to ALLDATA, and my local library is a rather mundane low key operation geared to kid's stuff. No indication of removable face plate, although console could have a pull-down curtain???
:Standing by…
5/3/2008 9:38:02 AMEdd
O.K ....by memory I do still remember the units being interconnected by designated A and B multi contact connectors of which about 6 lines in that cabling cluster were shielded.
That definitely sounds like what I ALSO ended up with ! ....couldn’t work with that...maybe only making out the shielded lines that I mentioned.
Probably if you hit the input with healthy enough signal the missing preamp module can be ignored.
Thinking about it... I am sure that the computer interfacing over at Adv Auto Technology is also utilizing our common USB B-A ‘puter to printer interfacing so I will carry a Y cable over there and tap into the serial data stream and catch it on a flash drive and then I can do a Si-PO conversion and then get its data transferred into a system and do my magic with it.
Will do that Monday...stand by for 6 or so pages of data with gooooooood legibility.
5/3/2008 5:59:50 PMMarv Nuce
EDD,
I think my blurry dwg calls out S(socket?)6 as "A" and S(socket?)7 as "B", and bubbles beside the amp box designates A or B connector with pin # along side. The chassis however, have no A/B/S designations anywhere. With cover removed, found J3 and J4 on the pc board though. Standing by for more input.
:O.K ....by memory I do still remember the units being interconnected by designated A and B multi contact connectors of which about 6 lines in that cabling cluster were shielded.
: Walt sent me a 5 page .gif file, but can't read most of the text
:That definitely sounds like what I ALSO ended up with ! ....couldn’t work with that...maybe only making out the shielded lines that I mentioned.
:Probably if you hit the input with healthy enough signal the missing preamp module can be ignored.
:Thinking about it... I am sure that the computer interfacing over at Adv Auto Technology is also utilizing our common USB B-A ‘puter to printer interfacing so I will carry a Y cable over there and tap into the serial data stream and catch it on a flash drive and then I can do a Si-PO conversion and then get its data transferred into a system and do my magic with it.
:Will do that Monday...stand by for 6 or so pages of data with gooooooood legibility.
5/3/2008 8:25:30 PMEdd
O.K., now..heres your data...all condensed down to 4 pages and color coded up and it certainly seems like all of the A and B cable connectors numbers are legible.
Most assuredly your pin 13 connection on the tuner asssembly will be utilizing common mode carrier technique wherein the DC power being routed to the preamp is RF choke coil isolated at each end such that amplified RF signal can be traveling back down the line that the DC power went up to it on.
For circumvention, you just inject your RF into terminal 13 thru capacitive isolation.
Herewith... your HOT linked references..all in PiNGed up format, so you may have to dub-l-click on... to mag it on up to full size….
>http://img215.imageshack.us/img215/4403/lexiusis300part1xg4.png
>http://img225.imageshack.us/img225/4629/lexiusis300part2ir6.png
>http://img212.imageshack.us/img212/3604/lexiusis300part3bf4.png
>http://img212.imageshack.us/img212/6665/lexiusis300part4ye6.png
5/3/2008 10:05:06 PMMarv Nuce
EDD,
Thanks!! Your the best. Clear as a bell. Saved them to my desktop and they printed out great. I'll have to digest these new drawings for a while, and decide on connector bodies. Thanks again.
:O.K., now..heres your data...all condensed down to 4 pages and color coded up and it certainly seems like all of the A and B cable connectors numbers are legible.
:Most assuredly your pin 13 connection on the tuner asssembly will be utilizing common mode carrier technique wherein the DC power being routed to the preamp is RF choke coil isolated at each end such that amplified RF signal can be traveling back down the line that the DC power went up to it on.
: For circumvention, you just inject your RF into terminal 13 thru capacitive isolation.
:Herewith... your HOT linked references..all in PiNGed up format, so you may have to dub-l-click on... to mag it on up to full size….
::>http://img215.imageshack.us/img215/4403/lexiusis300part1xg4.png
::>http://img225.imageshack.us/img225/4629/lexiusis300part2ir6.png
:: >http://img212.imageshack.us/img212/3604/lexiusis300part3bf4.png
:: >http://img212.imageshack.us/img212/6665/lexiusis300part4ye6.png
5/4/2008 12:53:36 PMMarv Nuce
EDD,
After digesting the new legible dwgs, the Stereo Component Amp's 2 connectors were easily identified using pin counts. The Radio-Player's 2 connectors are not as easy, unless I automatically assume one of them to be for external programming, data download, maintenance, repair, testing etc. The pin count of the larger is somewhat aligned with the diagram also.
5/6/2008 10:30:06 PMMarv Nuce
EDD,
Managed to cut from hardwood 3 bodies to fit the connector slots, and mark pin positions for drilling, but this is a self satisfaction project, so had to set it aside for a paying job on an RCA 86BK full cabinet/electronics restoration. Its already getting to be fun.
