I built this and was wondering because one side of the 120vac line is going to the input, could this harm the input device such as a cd player, or computer?
Safest thing is to use an isolation transformer.
:As long as you use a polarized plug and make sure the ground is wired to circuit ground then you should be safe...as long as the outlet you use is properly wired as well.
:Safest thing is to use an isolation transformer.
The ground is the round pin (or what looks like a half round from the AC wall outlet).
The narrow slot is considered "hot" and is where the alternating current power comes out. The wiring behind the outlet to this slot is usually black in the U.S.
The wide slot is considered the "common" and is supposed to be grounded. Using the white wire as a common grounded wire, means that everyone is working from the same zero voltage position.
Round hole
:Is the ground the larger or smaller pin?
::As long as you use a polarized plug and make sure the ground is wired to circuit ground then you should be safe...as long as the outlet you use is properly wired as well.
::Safest thing is to use an isolation transformer.
The "Ground" is the 3rd hole. The Neutral is the larger pin. The Hot is the smaller one. IF, it is wired correctly.
Ah yes…Sir Thomas, caught that just after releasing, and one can’t go backwards on correcting an initial post…just make addendas afterwards.
With the schematics separation of the filament supply windings on the back to back positioning, I couldn’t tie one filament lead into a tube filament like the original schematic did, thus the [B] designation at the top should be another [A], so that the two tube filaments get wired in series to be supplied by the 12VAC from the transformers center portion.
Of course, there is yet another option of using two like 6.3 secondary transformers, with the tubes wired in parallel.
