With a resistor substituted for the field coil, there might me a little more hum. That can be reduced by jacking up the filter cap values by maybe 25%, but not much more, particularly for the cap nearest the rectifier cathode.
Doug
:Nom, If you are suggesting a physical conversion - I don't think there is a simple or practical way to do it. It is possible, however, to replace a field coil speaker with a permanent magnet (PM) type by using an appropriate-sized choke as a substitute for the field coil and hooking the new PM speaker to the audio output. Please let us know your particular reason for doing so, and there might be more specific suggestions forthcoming.
:You can also substitute a power resistor for the field coil. The resistance should be about the same as the original field coil's DC resistance, often around 1K ohms, or so. The resistor wattage should be at least 2x the expected power disipation, I^2R, where I is the total plate current through the resistor.
:With a resistor substituted for the field coil, there might me a little more hum. That can be reduced by jacking up the filter cap values by maybe 25%, but not much more, particularly for the cap nearest the rectifier cathode.
:Doug
::Nom, If you are suggesting a physical conversion - I don't think there is a simple or practical way to do it. It is possible, however, to replace a field coil speaker with a permanent magnet (PM) type by using an appropriate-sized choke as a substitute for the field coil and hooking the new PM speaker to the audio output. Please let us know your particular reason for doing so, and there might be more specific suggestions forthcoming.
If the DC resistance is off, then the B+ voltages will be out of whack. If the inductance is off, then there might be a bit more or less hum.
Doug
:It would be easy to go the resistor route with what Doug told me, but how would you figure the choke value?
:Doug
:Doug....You'd still need an output transformer for impedence matching wouldn't you?...Neal
Yes. I'm unsure whether the xfmr is on the chassis or was part of the original speaker: http://www.nostalgiaair.org/PagesByModel/383/M0025383.pdf
:Doug
::Doug....You'd still need an output transformer for impedence matching wouldn't you?...Neal
:A choke of about 8 to 10 Henries will be fine as long as the current rating is sufficient.
Yes, all this reminds me of an old Truetone ( no cabinet) I bought for $5 as a teen. (45 yrs ago )
The original field coil was used and another xfmr for the audio out . What a mess of wires. But it worked .
