Belmont 6D111, series B
4/11/2008 4:44:17 PMSam
Question on my Belmont 6D111, series B. The radio has been recapped and works well. However sometimes when it's turned on the dial lamp flashes brightly (like a flash bulb) for few times. I have checked the bulb socket, wiring and replaced the bulb. Could this be a problem with the 35Z5 filament?
Thanks for you help.
4/11/2008 6:30:13 PMBill G.
:Question on my Belmont 6D111, series B. The radio has been recapped and works well. However sometimes when it's turned on the dial lamp flashes brightly (like a flash bulb) for few times. I have checked the bulb socket, wiring and replaced the bulb. Could this be a problem with the 35Z5 filament?
:Thanks for you help.
Hi Sam,
It is normal. All AC/DC sets do this to some extent. This is because cold filaments have less resistance than warm ones, however, the resistance bulb filament doesn't change as much.
As a result the bulb gets a jolt at every turn on.
If you think it is excessive, check the resistor that goes between the bulb, it may be open.
Best Regards,
Bill Grimm
4/11/2008 7:41:36 PMBill G.
By the way, Belmont 6D111 are really cool! I want one.
Best regards,
Bill Grimm
4/12/2008 9:06:49 AMSam
Thanks for the help!
Sam
:By the way, Belmont 6D111 are really cool! I want one.
:Best regards,
:Bill Grimm
