Sean: Play Things of the Past probably has what you need. See: http://www.oldradioparts.com/2a22fil.txt
What's wrong with your existing control?
Steve
I think a 3.5 should work just fine, without anything across it. Try it and see, you are not going to hurt anything.
:Sean: Play Things of the Past probably has what you need. See: http://www.oldradioparts.com/2a22fil.txt
:What's wrong with your existing control?
:Steve
