Hi Mike,
My suspicion on your 6AV6 is that it has a detached plate. This is quite rare, so tube testers don't test for it. They typically test using the grid as a plate, and check the cathode to grid current on the triode section. If you are curious, look inside the tube and see if a detecment can be seen. With the NIB 6AV6 in the socket, you may get a plate voltage that is too high, too.
In old schematics, 'M' means thousand, or K in today's terminology. As you suspect your R1 and R14 are shot. Even their color codes indicate that they should be 100K, not 1 Meg.
Best Regards,
Bill Grimm
Looks like R1 is an isolation / dropping resistor tailoring the needs of the AVC feed to the RF amp stage of the set .
While your R-uh-14 is the companion to R13 along with C24 in supplying B+ to the 6SQ7 plate circuitry along with some tonal coloration by partial bypassing of some high AF frequencies.
Both values are one hundred thousand ohms….no ambiguity there …eh ?
No ideas on the “Great / Selective 6AV6 Fiasco” since the tube doesn’t involve the connections of a tube element to two connections , such that a tube pin wiring connection might be made on one set and not on another. You might further investigate by taking a .01---.1 ufd paper cap and take its long leads and position them such that the injection of “hot” 6.3 VAC from its filament tube pin connection is injected into the 1st grid of the 6AV6 and confirm gain / amplification by a louuuud hummmmm.
If no audio then, inter connect the cap temporarily with test / clip leads and hold down the tube with a thumb pressed into the top of it and whack the side of the tube with a wooden dowel to check for loose internal spot welds, in which case the tube might emit a burst of audio / static during that time element of intermittent contact.
Then, according to the triodes condition, that would narrow it down to the possibility of solely the diode sections being involved.
Welllllll, I got all the way to the 5Y3 tube before smelling smoke and seeing a dab before I yanked the the plug. I didn't replace any of the caps and think it probably isn't worth my time doing so. Think this one will become a "parts" radio.
