How can I tell the difference between transformers?
3/31/2008 7:01:33 PMMarc
I have several different audio transformers. Most of them are tagged and I can figure out what they are. One in particular has no ID whatsoever. There are 8 pins. It seems two of them are high resistance inputs and the rest are all outputs of varying resistances. Can anyone tell me how to figure out what kind of transformer it is? I am not sure how to figure out if it is say a line, interstage, output, etc.
Marc
4/2/2008 1:17:57 PMLewis Linson
:I have several different audio transformers. Most of them are tagged and I can figure out what they are. One in particular has no ID whatsoever. There are 8 pins. It seems two of them are high resistance inputs and the rest are all outputs of varying resistances. Can anyone tell me how to figure out what kind of transformer it is? I am not sure how to figure out if it is say a line, interstage, output, etc.
:Thanks,
: Marc
Mare:
Here is some info I found useful...hope it helps.
http://www.radioremembered.org/outimp.htm
4/2/2008 7:59:37 PMMarc
::I have several different audio transformers. Most of them are tagged and I can figure out what they are. One in particular has no ID whatsoever. There are 8 pins. It seems two of them are high resistance inputs and the rest are all outputs of varying resistances. Can anyone tell me how to figure out what kind of transformer it is? I am not sure how to figure out if it is say a line, interstage, output, etc.
::Thanks,
:: Marc
:Mare:
:Here is some info I found useful...hope it helps.
:Lewis
:http://www.radioremembered.org/outimp.htm
Thank you, that is just what I was looking for
