Your electrical background will help a lot, but this would not be my choice of a set to start on. It's got 10 tubes, 3-bands, 2-stages of audio, push-pull final audio, etc.
Somebody canibalized the speaker, tubes, etc., which suggests that something else was wrong first. The original speaker was a dynamic model, with a field coil. You could replace it with a modern permanent-magnet speaker, and put a power resistor in place of the field coil.
As far as the missing knobs, you might be satisfied with newly manufactured, wood-looking generics.
The replacement dial cover might be easy - IF it is round.
Probably the first thing to check is the power xmfr - see if each of the windings has continuity.
With a set of tubes, new capacitors, knobs, speaker, and possibly other things, this is going to run maybe $200 in parts.
Doug
:I salvaged my great-grandmothers 1937 zenith model 10-S-153 from my grandmothers garage before it could get pitched during her recent move. My situation is that I would like to get it working for her 85th birthday but have no idea where to start. It needs knobs, front glass plate over the dial, tubes, speaker(does that have to be original?), the works. I am an electrician and can read a schematic and understand the functions of the components but I need a resource. Please help!
To name a couple, www.radiodaze.com and www.tubesandmore.com have in the past supplied Zenith knobs. Others on here can give you more names. There's a place that I was going to buy knobs from that probably has a dial bezel for you and many more things, but it was too expensive for me at the time so I didn't buy the knobs. I can't remember the name of the place at the moment. Doug or Norm probably have the name, or maybe Edd.
If the dial cover is circular, Bill Turner is a source: http://www.dialcover.com/ He is located in a suburb of St. Louis.
Doug
:It definitely isn't a stereo (it's a radio), but several suppliers sell, or at least used to sell, Zenith knobs of many kinds. If you can't find exact replacements, you most likely can find some that will look good on the radio. There are other suppliers that may have the glass used on the dial.
:To name a couple, www.radiodaze.com and www.tubesandmore.com have in the past supplied Zenith knobs. Others on here can give you more names. There's a place that I was going to buy knobs from that probably has a dial bezel for you and many more things, but it was too expensive for me at the time so I didn't buy the knobs. I can't remember the name of the place at the moment. Doug or Norm probably have the name, or maybe Edd.
:T.
::Thank you Doug. I would be willing to pay to have the stereo fixed and buy whatever parts it needs. I live in the Chicagoland area...any ideas of who to call or email. also, my dad said that he dropped this radio while moving this piece years ago.
::Jordan, here is the schematic: http://www.nostalgiaair.org/PagesByModel/682/M0024682.pdf
::Your electrical background will help a lot, but this would not be my choice of a set to start on. It's got 10 tubes, 3-bands, 2-stages of audio, push-pull final audio, etc.
::Somebody canibalized the speaker, tubes, etc., which suggests that something else was wrong first. The original speaker was a dynamic model, with a field coil. You could replace it with a modern permanent-magnet speaker, and put a power resistor in place of the field coil.
::As far as the missing knobs, you might be satisfied with newly manufactured, wood-looking generics.
::The replacement dial cover might be easy - IF it is round.
::Probably the first thing to check is the power xmfr - see if each of the windings has continuity.
::With a set of tubes, new capacitors, knobs, speaker, and possibly other things, this is going to run maybe $200 in parts.
::Doug
:::I salvaged my great-grandmothers 1937 zenith model 10-S-153 from my grandmothers garage before it could get pitched during her recent move. My situation is that I would like to get it working for her 85th birthday but have no idea where to start. It needs knobs, front glass plate over the dial, tubes, speaker(does that have to be original?), the works. I am an electrician and can read a schematic and understand the functions of the components but I need a resource. Please help!
Best Regards,
Bill Grimm
Best Regards,
Bill Grimm
