Silvertone 1928
3/22/2008 4:45:16 PMFrank Goddard
Hi Folks.
I am repairing a Silvertone 1928. I notice that the tube (1B1) is used as a balast tube. Can anyone tell me why a tube is used in this way rather than a resistor or other cheaper way,
thanks.
Frank Goddard. Doncaster England.
3/23/2008 11:24:43 AMJon
:Hi Folks.
:I am repairing a Silvertone 1928. I notice that the tube (1B1) is used as a balast tube. Can anyone tell me why a tube is used in this way rather than a resistor or other cheaper way,
:thanks.
:Frank Goddard. Doncaster England.
Frank, My Silvertone model 1926 uses the same ballast and Radiodoc informed me when I was restoring it that it was used to regulate the 3.2v dry cell batteries down to 2 volts for operation. Mine was missing and as long as I supplied 2.o v. I could just jump the pins. The 1B1 is rated @ 1.0v., .36amp., 2.8 ohms. I later found a 1B1 have used it both ways without any problems.
Hope this helps,
Jon.
3/23/2008 12:01:10 PMLewis Linson
::Hi Folks.
::I am repairing a Silvertone 1928. I notice that the tube (1B1) is used as a balast tube. Can anyone tell me why a tube is used in this way rather than a resistor or other cheaper way,
::thanks.
::Frank Goddard. Doncaster England.
:Frank, My Silvertone model 1926 uses the same ballast and Radiodoc informed me when I was restoring it that it was used to regulate the 3.2v dry cell batteries down to 2 volts for operation. Mine was missing and as long as I supplied 2.o v. I could just jump the pins. The 1B1 is rated @ 1.0v., .36amp., 2.8 ohms. I later found a 1B1 have used it both ways without any problems.
:Hope this helps,
:Jon.
Frank:
The reason they used a ballast tube instead of a resistor: the tube filament is made of a metal whose resistance changes with temperature. When the battery is new, the tube filament is warmer and has a higher resistance. As the battery discharges, the filament runs cooler, the resistance is lower, and the current stays about the same. As Jon said, get a steady source of two Volts, and you will not have to compensate for the battery discharging. Jumper the ballast tube, and listen.
3/23/2008 2:31:22 PMFrank Goddard
:::Hi Folks.
:::I am repairing a Silvertone 1928. I notice that the tube (1B1) is used as a balast tube. Can anyone tell me why a tube is used in this way rather than a resistor or other cheaper way,
:::thanks.
:::Frank Goddard. Doncaster England.
::Frank, My Silvertone model 1926 uses the same ballast and Radiodoc informed me when I was restoring it that it was used to regulate the 3.2v dry cell batteries down to 2 volts for operation. Mine was missing and as long as I supplied 2.o v. I could just jump the pins. The 1B1 is rated @ 1.0v., .36amp., 2.8 ohms. I later found a 1B1 have used it both ways without any problems.
::Hope this helps,
::Jon.
:Frank:
:The reason they used a ballast tube instead of a resistor: the tube filament is made of a metal whose resistance changes with temperature. When the battery is new, the tube filament is warmer and has a higher resistance. As the battery discharges, the filament runs cooler, the resistance is lower, and the current stays about the same. As Jon said, get a steady source of two Volts, and you will not have to compensate for the battery discharging. Jumper the ballast tube, and listen.
:Lewis
:Lewis
Thank you both. This is great information. When running up the LT I used a 2 volt supply.No wonder the filaments were running low. Perhaps this could explain the very low volume levels too. Anyhow. I am still way off with the repair but now I don't have to look for problems that don't exist. Thanks again. Frank
3/24/2008 4:59:03 AMFrank Goddard
::::Hi Folks.
::::I am repairing a Silvertone 1928. I notice that the tube (1B1) is used as a balast tube. Can anyone tell me why a tube is used in this way rather than a resistor or other cheaper way,
::::thanks.
::::Frank Goddard. Doncaster England.
:::Frank, My Silvertone model 1926 uses the same ballast and Radiodoc informed me when I was restoring it that it was used to regulate the 3.2v dry cell batteries down to 2 volts for operation. Mine was missing and as long as I supplied 2.o v. I could just jump the pins. The 1B1 is rated @ 1.0v., .36amp., 2.8 ohms. I later found a 1B1 have used it both ways without any problems.
:::Hope this helps,
:::Jon.
::Frank:
::The reason they used a ballast tube instead of a resistor: the tube filament is made of a metal whose resistance changes with temperature. When the battery is new, the tube filament is warmer and has a higher resistance. As the battery discharges, the filament runs cooler, the resistance is lower, and the current stays about the same. As Jon said, get a steady source of two Volts, and you will not have to compensate for the battery discharging. Jumper the ballast tube, and listen.
::Lewis
::Lewis
:Thank you both. This is great information. When running up the LT I used a 2 volt supply.No wonder the filaments were running low. Perhaps this could explain the very low volume levels too. Anyhow. I am still way off with the repair but now I don't have to look for problems that don't exist. Thanks again. Frank
One last question. What was the year of manufacture for the Model 1928.Thanks again,
Frank
