6F6 substitute
3/22/2008 6:55:01 AMDes Miles
Can I safely replace a 6F6 tube with a 6V6G. Specs and valve base seem to be similar, filament current is less for the 6V6G. Should I be aware of anything?
I have aquired +/- 150 NOS. of the 6V6G tubes so I better start using them! Thanks.
3/22/2008 8:49:04 AMJim
:Can I safely replace a 6F6 tube with a 6V6G. Specs and valve base seem to be similar, filament current is less for the 6V6G. Should I be aware of anything?
:I have aquired +/- 150 NOS. of the 6V6G tubes so I better start using them! Thanks.
Des,
You might hear a slight loss of volune if at all.
Jim
