3/20/2008 8:06:32 PMKris(60611:0)
Hi, I think my Majestic power supply may be wired wrong but here are the details. The blue 2.5 v wires go to the 45 outputs and the center tapped red wires are going to the 27's. This is opposite of the schematic but the wiring looks factory; do they have it wrong and isn't the center tapped 2.5v supply supposed to go the the outputs?
3/20/2008 11:57:28 PMThomas Dermody(60617:60611)
Center tapped 2.5 volts should go to the 45s.
3/21/2008 10:33:33 AMKris(60620:60617)
That's what I figured, but would the radio have functioned well hooked up the other way, as I said this looked factory but is is not the first one I have worked on that was wrong.
:Center tapped 2.5 volts should go to the 45s.
:T.
