I wanted to buy an Lm317 IC regulator and a few other required parts. ( although most of us already have the extra parts laying around)
But I found ALL the parts in a nice little kit including a printed circuit board to build it on for only $13.
Then... I also lucked-out and found a "neat" 2 amp transformer for it for only $2.88.
The entire thing went together in minuets and had I bought all the parts separately I don't think it would be much cheaper.
The nice thing about the transformer is that it is a 25v CT.
12.5 - 0 - 12.5
The 25 volts AC output from the transformer kicks up at the input filter enough to get about 30vdc out nicely if needed. And with a proper heat sink the LM317 should run cool.
Now since the Lm317 is a "linear" regulator it normally has to dissipate all the extra wattage for the excess voltage not used should you decide to adjust the supply way down to about 5 volts or less.
So In order to use a reasonable sized heat-sink, I realized you can put a switch on the center tap so that when you want to keep the output below 15 volts you can switch in only one 12.5v AC winding and if the output is going to be over 15 volts you can switch it so that both windings are used to total 25vac.
This should significantly reduce any wasted heat dissipation and strain on the Lm317 at the lower voltages.
Here's the cheap parts:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=129-035
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=320-216
I assume that with a heat sink and the lower AC voltage, it could supply more than 1A?
Doug
:I was looking around for some parts for an adjustable 1.5v-30vDC regulated 1-amp bench testing power-supply and I came up with a some easy & low cost parts.
:I wanted to buy an Lm317 IC regulator and a few other required parts. ( although most of us already have the extra parts laying around)
:But I found ALL the parts in a nice little kit including a printed circuit board to build it on for only $13.
:Then... I also lucked-out and found a "neat" 2 amp transformer for it for only $2.88.
:The entire thing went together in minuets and had I bought all the parts separately I don't think it would be much cheaper.
:The nice thing about the transformer is that it is a 25v CT.
:12.5 - 0 - 12.5
:The 25 volts AC output from the transformer kicks up at the input filter enough to get about 30vdc out nicely if needed. And with a proper heat sink the LM317 should run cool.
:Now since the Lm317 is a "linear" regulator it normally has to dissipate all the extra wattage for the excess voltage not used should you decide to adjust the supply way down to about 5 volts or less.
:So In order to use a reasonable sized heat-sink, I realized you can put a switch on the center tap so that when you want to keep the output below 15 volts you can switch in only one 12.5v AC winding and if the output is going to be over 15 volts you can switch it so that both windings are used to total 25vac.
:This should significantly reduce any wasted heat dissipation and strain on the Lm317 at the lower voltages.
:Here's the cheap parts:
:http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=129-035
:http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=320-216
First, the internal circuitry of the LM317T can only handle 1.5 A of current as an absolute maximum. More on this below.
Secondly, and this is IMPORTANT, the LM317T is a linear regulator. This means that it dissipates the excess voltage as heat, with more heat produced as the voltage is set lower and lower. You MUST have a heatsink mounted on the regulator that is capable of dissipating the heat produced.
If you need more than 1.5A of current, and have a heatsink large enough to handle the wattage
....here's some at a low cost:
http://www.futurlec.com/HeatTO220.shtml
or...
(old stereos and amplifiers are great for finding massive heat-sinks, btw), you can use an LM350, which is rated up to 3 A and is identical to the LM317 in all other respects. The LM338 is also compatible, and is rated up to 5 A."
Keep your circuit using the LM317 and simply add a series pass transistor. This will up the power by tenfold (if the transformer can cope with the power). Using a motorola 250W transistor for a few dollars, 2 resistors and a nice heatsink.An MJ11015 would be a good start, that is what I use.
:: you can use an LM350, which is rated up to 3 A and is identical to the LM317 in all other respects. The LM338 is also compatible, and is rated up to 5 A."
:Keep your circuit using the LM317 and simply add a series pass transistor. This will up the power by tenfold (if the transformer can cope with the power). Using a motorola 250W transistor for a few dollars, 2 resistors and a nice heatsink.An MJ11015 would be a good start, that is what I use.
More info here:
http://ourworld.compuserve.com/homepages/Bill_Bowden/page12.htm
