601-s Sparton parts identification
3/16/2008 4:24:23 PMMIKE C
My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/16/2008 5:09:30 PMNeal Morris
Could you mean 601-B?
:My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/17/2008 7:31:55 AMMIKE C
It may be 601-5 or 601-S, but definitely not 601-B. The power resistors I have are 10W not 10K. Typo there. I'm sure the metal whatever is influencing things because I can't get the dial lamp to work.
:Could you mean 601-B?
::My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/17/2008 11:44:36 AMphil
mike,the only resistor in the parts list bigger than 1/4 watt is r14,a 1.8 k resistor.
:It may be 601-5 or 601-S, but definitely not 601-B. The power resistors I have are 10W not 10K. Typo there. I'm sure the metal whatever is influencing things because I can't get the dial lamp to work.
::Could you mean 601-B?
:::My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/17/2008 5:33:26 PMMIKE C
:mike,the only resistor in the parts list bigger than 1/4 watt is r14,a 1.8 k resistor.
::It may be 601-5 or 601-S, but definitely not 601-B. The power resistors I have are 10W not 10K. Typo there. I'm sure the metal whatever is influencing things because I can't get the dial lamp to work.
:::Could you mean 601-B?
::::My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/17/2008 5:41:10 PMMIKE C
R13 is actually .5 watt but that was readily identifiable. I think I'll use a 2k 10 watt power resistor as r14, but I still don't know what the flat metal clad object is between 2 & 3 of the 35z5 tube. Any ideas on what to place there?
3/18/2008 2:09:33 PMMIKE C
Does anyone have a clue what this metal clad item is and what it does???
:R13 is actually .5 watt but that was readily
::mike,the only resistor in the parts list bigger than 1/4 watt is r14,a 1.8 k resistor.
:::It may be 601-5 or 601-S, but definitely not 601-B. The power resistors I have are 10W not 10K. Typo there. I'm sure the metal whatever is influencing things because I can't get the dial lamp to work.
::::Could you mean 601-B?
:::::My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/18/2008 2:47:08 PMphil
from the desciption i'm guessing cap but don't see any listed in the schematic between those pins. are there any markings? can you post pic?
:Does anyone have a clue what this metal clad item is and what it does???
::R13 is actually .5 watt but that was readily
:identifiable. I think I'll use a 2k 10 watt power resistor as r14, but I still don't know what the flat metal clad object is between 2 & 3 of the 35z5 tube. Any ideas on what to place there?
:::mike,the only resistor in the parts list bigger than 1/4 watt is r14,a 1.8 k resistor.
::::It may be 601-5 or 601-S, but definitely not 601-B. The power resistors I have are 10W not 10K. Typo there. I'm sure the metal whatever is influencing things because I can't get the dial lamp to work.
:::::Could you mean 601-B?
::::::My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/18/2008 2:56:12 PMphil
hold the phone,could it be c21?
:from the desciption i'm guessing cap but don't see any listed in the schematic between those pins. are there any markings? can you post pic?
::Does anyone have a clue what this metal clad item is and what it does???
:::R13 is actually .5 watt but that was readily
::identifiable. I think I'll use a 2k 10 watt power resistor as r14, but I still don't know what the flat metal clad object is between 2 & 3 of the 35z5 tube. Any ideas on what to place there?
::::mike,the only resistor in the parts list bigger than 1/4 watt is r14,a 1.8 k resistor.
:::::It may be 601-5 or 601-S, but definitely not 601-B. The power resistors I have are 10W not 10K. Typo there. I'm sure the metal whatever is influencing things because I can't get the dial lamp to work.
::::::Could you mean 601-B?
:::::::My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/18/2008 3:13:33 PMphil
on your dial lamp issue probably the tap on the 35z5 is bad?
:hold the phone,could it be c21?
::from the desciption i'm guessing cap but don't see any listed in the schematic between those pins. are there any markings? can you post pic?
:::Does anyone have a clue what this metal clad item is and what it does???
::::R13 is actually .5 watt but that was readily
:::identifiable. I think I'll use a 2k 10 watt power resistor as r14, but I still don't know what the flat metal clad object is between 2 & 3 of the 35z5 tube. Any ideas on what to place there?
:::::mike,the only resistor in the parts list bigger than 1/4 watt is r14,a 1.8 k resistor.
::::::It may be 601-5 or 601-S, but definitely not 601-B. The power resistors I have are 10W not 10K. Typo there. I'm sure the metal whatever is influencing things because I can't get the dial lamp to work.
:::::::Could you mean 601-B?
::::::::My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/19/2008 7:34:53 AMMIKE C
:on your dial lamp issue probably the tap on the 35z5 is bad?
::hold the phone,could it be c21?
:::from the desciption i'm guessing cap but don't see any listed in the schematic between those pins. are there any markings? can you post pic?
::::Does anyone have a clue what this metal clad item is and what it does???
:::::R13 is actually .5 watt but that was readily
::::identifiable. I think I'll use a 2k 10 watt power resistor as r14, but I still don't know what the flat metal clad object is between 2 & 3 of the 35z5 tube. Any ideas on what to place there?
::::::mike,the only resistor in the parts list bigger than 1/4 watt is r14,a 1.8 k resistor.
:::::::It may be 601-5 or 601-S, but definitely not 601-B. The power resistors I have are 10W not 10K. Typo there. I'm sure the metal whatever is influencing things because I can't get the dial lamp to work.
::::::::Could you mean 601-B?
:::::::::My schematic does not really identify a flat metal encased cap/resistor that goes betweetn pins 2 & 3 of the35z5 tube or the cylindrical ...what appears to be wood encased power resistor between pins 2 & 8 of the same tube. The cylindrical object says 10w but I can't determine the ohms. Any help identifying these 2 items?? The biggest 10k power resistor I have on hand is only rated 2k ohms. Would really appreciate any help.
3/19/2008 7:37:54 AMMIKE C
Computer giving me fits this morning. Took pics but after a little reading I have no idea whatsoever on how to post them.
