On the schematic, the AVC is at the junction of R10 (1 megohm resistor) and the wire from the bottom of the secondary winding of the 1st IF transformer (the wire color possibly may be black or brown). To double check for the right 1 megohm resistorjunction, just measure the resistance from the 6K7 grid cap to the 1 meg resistor. You should measure around 7 Ohms resistance. To measure the AVC with the radio on, use a high impedance VOM from that point to chassis. There should be a minus voltage on the AVC which will vary according to the strength of the signal into the radio.
:I've been told by I can measure IF Signal Strength my measuring -voltage on my AVC line. Could someone please help me identify it?
On that digital radio alignment trick you've taught me, will a car radio do? I can't see why not.
:Neal: Radiodoc has identified your test points. The AVC bus runs between your converter, IF Amp and detector circuits. The negative avc voltage is used to bias the converter and i-f tubes. That way when you receive a very strong station, a large negative control bias is placed on the r-f tubes that reduces their gain. When you receive a weak station, the opposite is true. When you align the radio using the avc voltage, you are looking for the most negative voltage (strongest reading), regardless of your speaker volume. If you use your speaker output voltage for alignment purposes and you don't have the volume at max, the AVC circuit is working against you by trying to keep all the signals at the same level and it's more difficult to find peak output (avc is constantly adjusting the gain).
:Steve
Feedback pls…..on that old Warhorse….what type of DC metering did you finally use and what was the highest AVC voltage you experienced on your strongest signal in the initial evaluatory metering that I had mentioned? And IF you still remember , its increased value when you shunted the tail of the AVC buss to ground ? I am definitely more likely to know those specs for newer receivers than that one.
I used a Fluke 117 (VOM) and the highest negative voltage I remember on the AVC line was -58vdc. I haven't gone through the steps you outlined but I am going to align it one more time after I get the last few paper caps replaced and bad wire replaced. I'll use your proceedure as best as I can understand it and give you more feedback at that time.
I used a 2nd harmonic on 910kc to nail down my IF frequency by rocking my signal generator and finding the 'zero-beat'. A proceedure Steve outlined for me. Right now it sounds really good and my SW is lined up great. There is a little room for improvement on BC and I hope to achieve that when I align it next time. Like I say, more feedback after I work my way through the proceedure you gave me.
Neal
:Feedback pls…..on that old Warhorse….what type of DC metering did you finally use and what was the highest AVC voltage you experienced on your strongest signal in the initial evaluatory metering that I had mentioned? And IF you still remember , its increased value when you shunted the tail of the AVC buss to ground ? I am definitely more likely to know those specs for newer receivers than that one.
Ahhhh soooo…so it also WAS, well up in the threshold that I am used to seeing on GT and miniature tubed versions of
receivers . That shunting off of the frontal end of the AVC loop such that it will be ill affected by corrective voltage feedback
certainly solves half the problem along with the initial evaluation of the max AVC to be expected and THEN the setting of working alignment input signal level well down the sensitivity curve that I mentioned.
When everyone else is working with those typical 3-6-9-….or run up the flag if you reach 12v……AVC alignment levels, you can be well up from working with a small level ….such that my oft time mentioned 1/32 of a turn of an alignment adjustment can be seen.
With the Fluke “Electricians” 117’s utilization …that’s still an end “digit bobbler”….. versus an analog, but the Flukes minimal invasive loading, along with the higher AVC level present should minimize that metering inconvenience….Me, I’m still a dyed in the wool analog metering freak for tuning procedures. However, for the reading out or setting to 4.9999---5.0001 VDC, gimme the Fluke….. Duke! ...BUT…who has to set voltages to those exacting extremes, unless it would be a calibration lab ?
