Medco radio
3/15/2008 9:14:08 AMFred
Trying to find information on a Medco Radio. It’s a AM and Short Wave with 3 knobs under the dial (vol, tuning, switch OFF AM SW). It has 5 tubes (50L6, 35Z5, 12SQ7, 12SK7, 12SA7). Its in a wood case and there are no numbers on the chassis or case.
3/20/2008 1:40:48 PMCarl T
:Trying to find information on a Medco Radio. It’s a AM and Short Wave with 3 knobs under the dial (vol, tuning, switch OFF AM SW). It has 5 tubes (50L6, 35Z5, 12SQ7, 12SK7, 12SA7). Its in a wood case and there are no numbers on the chassis or case.
Fred,
Mallory's Radio Service Encylopedia only lists 4 models under Telesonic (Medco). Only the model 1642 matches your tube line up, but it is AM only.
Carl T
3/24/2008 5:29:00 PMFred
::Trying to find information on a Medco Radio. It’s a AM and Short Wave with 3 knobs under the dial (vol, tuning, switch OFF AM SW). It has 5 tubes (50L6, 35Z5, 12SQ7, 12SK7, 12SA7). Its in a wood case and there are no numbers on the chassis or case.
:Fred,
:Mallory's Radio Service Encylopedia only lists 4 models under Telesonic (Medco). Only the model 1642 matches your tube line up, but it is AM only.
:Carl T
Carl:
Thanks for the info. Any ideas on where I can get a schematic?
Fred
3/24/2008 9:34:50 PMCarl C
:::Trying to find information on a Medco Radio. It’s a AM and Short Wave with 3 knobs under the dial (vol, tuning, switch OFF AM SW). It has 5 tubes (50L6, 35Z5, 12SQ7, 12SK7, 12SA7). Its in a wood case and there are no numbers on the chassis or case.
::Fred,
::Mallory's Radio Service Encylopedia only lists 4 models under Telesonic (Medco). Only the model 1642 matches your tube line up, but it is AM only.
::Carl T
:Carl:
:Thanks for the info. Any ideas on where I can get a schematic?
:Fred
Fred: Contact "Old Jim" At http://www.olditemsale.com/index.html
He lists Medco models 1635, 1636, 1642, and 1643
Hope this helps.
Carl C
