variac and isolation transformer
3/10/2008 9:18:06 PMJesse Hancock
Are the above items really must haves when working on tube radios? Just wondering, I have done some work to a old motorola, without the aides of these... But only after discharging the electrolytics, and of course unplugging the radio.. If it sounds like a dumb question then let me know.. If not, then is the aforementioned items for testing your work?
3/10/2008 10:10:29 PMAllanG
:Are the above items really must haves when working on tube radios? Just wondering, I have done some work to a old motorola, without the aides of these... But only after discharging the electrolytics, and of course unplugging the radio.. If it sounds like a dumb question then let me know.. If not, then is the aforementioned items for testing your work?
Jesse:
I guess its a matter of preference. The variac is useful to bring up radios to full power slowly which can help check for shorts and let the old electrolytics re-form if possible. They are also useful for testing curtain burner sets with a bad or missing resistor cord. You can certainly prevent serious damage to the set by using a variac. Of course, you can also use the "dim bulb test" to check the power transformer. I got along without a variac for quite a while, so again its personal preference. Given a choice, I'd rather have one and they are relatively inexpensive.
The isolation transformer is another issue. This is really a safety item, especially with AC/DC sets. Its easy to burn up vintage test equipment without one, as well as getting a deadly shock. I consider both of the above pieces of equipment as "basic" and still use a GFCI circuit as additional protection.
Just my opinion, others may feel differently.
Regards,
Allan
3/11/2008 6:58:43 AMBrian
Being new to old radios, I wouldn't work on a radio without them.
3/11/2008 8:52:59 AMLewis Linson
:Being new to old radios, I wouldn't work on a radio without them.
If you don't want to purchase the above items, at least get a series light bulb and a GFCI from your local Home Depot (or whatever) and run the workbench through that. They are only about 7-8 bucks, and will lighten the shock considerably if you get caught between hot and ground. The series light bulb will perhaps keep you from generating expensive "magic smoke"
::Are the above items really must haves when working on tube radios? Just wondering, I have done some work to a old motorola, without the aides of these... But only after discharging the electrolytics, and of course unplugging the radio.. If it sounds like a dumb question then let me know.. If not, then is the aforementioned items for testing your work?
3/11/2008 11:20:12 AMGary W. Prutchick
Hi Jesse,
One of the most important pieces of equipment on my bench is an isolation transformer. I never work on a radio unless it is iosolated from the power lines.
This protects you from a serious shock and potects your test equipment as well.
When I start a restoration, the first 2 things I do are:
1. On radios without power transformers I change the power cord to a polarized cord, ensuring the polarity is correct. (white (neutral) is connected to chassis).
NOTE: Also check your bench and make sure polarity is correct there.
2. Install a fuse in the radio. Normally I use a pig-tail fuse. I calculate the rating based on the power rating of the radio. This information is usually on the name plate.
Gary
3/11/2008 11:27:39 AMMarv Nuce
Jesse,
I solved both problems with a US(120VAC)/European(240VAC) transformer backward, but only for transformer/switch tests, and no tubes. If all voltages are about half of normal up to the rectifier plates socket pins, then all should be well when full line is supplied.
