I can provide the Photofact for model 610 (six tube FM only tabletop)however I can find no documentaion for a 610U.
Dennis
Dennis,
I have a photofact set 283 folder 6. It is marked Granco 610. The back of my radio says 610U. May mean the color of the case? I just included it in the model #.
Tony
Those are just my initial thoughts . . . check 'em out .
:::::Bill,
:::::What is the difference between models 610 and 610U ?
:::::I can provide the Photofact for model 610 (six tube FM only tabletop)however I can find no documentaion for a 610U.
:::::Dennis
:::::I don't know if there is a difference. I was using the model number of a picture of my radio. It may refer to the color of the cabinet. Thanks for any help.Bill
::::Dennis,
::::I have a photofact set 283 folder 6. It is marked Granco 610. The back of my radio says 610U. May mean the color of the case? I just included it in the model #.
::::Tony
::::My E-mail is bandsgee@cmaaccess.com
::Bill
:::I want to thank Tony and Dennis for their help. I have the radio playing now but the small tuning slug is broken. How should I proceed? Some of it is still in the tube.Volume is low. Is that due to slug?
:Bill
: : : : ![]() : : : : : : : :Sir Bill . . . . : : :Clarification please . . . . . . wheeeeeeeeech slug ? . . . .as there are potentially 2 slugs each in the IF transformateurs along with 2 in :the ratioless- detecticatorating T-tormer. : : :The RF front ends L4 and osc L4 are air would coils and thereby dependent upon compressing or "knifing" their inductive values. : : :Thereby, being very low inductance and no needed use of associative slugs. : : :How's about taking another analytical path initially . . . . with it being in the respect of checking out that FM detector stages 2 ufd summing capacitor C2 to :see if time hasn't taken a toll on its electrolyte and is now currently residing waaaaay down in the .1 ufd range. : : :Additionally, is the power supply "healthy" . . . . . and having in the order of its prescribed ~ 130VDC at the plate of the 35C5 tube ? : : :Also is the 19T8's 220 K plate load resistor and its 4.7 meg grid resistors being within tolerances? : : :Also its . . . and the other tubes screen and plate voltage levels. ?
: : : : : :The man who can smile when things go wrong has just thought of someone he can blame it on. : : : : ![]() : : : |
:: :: :: :: ![]() :: :: :: :: :: :: :: ::Sir Bill . . . . :: :: ::Clarification please . . . . . . wheeeeeeeeech slug ? . . . .as there are potentially 2 slugs each in the IF transformateurs along with 2 in ::the ratioless- detecticatorating T-tormer. :: :: ::The RF front ends L4 and osc L4 are air would coils and thereby dependent upon compressing or "knifing" their inductive values. :: :: ::Thereby, being very low inductance and no needed use of associative slugs. :: :: ::How's about taking another analytical path initially . . . . with it being in the respect of checking out that FM detector stages 2 ufd summing capacitor C2 to ::see if time hasn't taken a toll on its electrolyte and is now currently residing waaaaay down in the .1 ufd range. :: :: ::Additionally, is the power supply "healthy" . . . . . and having in the order of its prescribed ~ 130VDC at the plate of the 35C5 tube ? :: :: ::Also is the 19T8's 220 K plate load resistor and its 4.7 meg grid resistors being within tolerances? :: :: ::Also its . . . and the other tubes screen and plate voltage levels. ?
:: :: :: :: :: ::The man who can smile when things go wrong has just thought of someone he can blame it on. :: :: :: :: ![]() :: :: :: |
::: ::: ::: ::: ![]() ::: ::: ::: ::: ::: ::: ::: :::Sir Bill . . . . ::: ::: :::Clarification please . . . . . . wheeeeeeeeech slug ? . . . .as there are potentially 2 slugs each in the IF transformateurs along with 2 in :::the ratioless- detecticatorating T-tormer. ::: ::: :::The RF front ends L4 and osc L4 are air would coils and thereby dependent upon compressing or "knifing" their inductive values. ::: ::: :::Thereby, being very low inductance and no needed use of associative slugs. ::: ::: :::How's about taking another analytical path initially . . . . with it being in the respect of checking out that FM detector stages 2 ufd summing capacitor C2 to :::see if time hasn't taken a toll on its electrolyte and is now currently residing waaaaay down in the .1 ufd range. ::: ::: :::Additionally, is the power supply "healthy" . . . . . and having in the order of its prescribed ~ 130VDC at the plate of the 35C5 tube ? ::: ::: :::Also is the 19T8's 220 K plate load resistor and its 4.7 meg grid resistors being within tolerances? ::: ::: :::Also its . . . and the other tubes screen and plate voltage levels. ?
::: ::: ::: ::: ::: :::The man who can smile when things go wrong has just thought of someone he can blame it on. ::: ::: ::: ::: ![]() ::: ::: ::: |
Ahhhhhhhhhh Soooooooooo . . . . with your most honnable info . . .and evaluating it, seems like you just might have have found yourself what is called a
::Bill:
::Your final post failed to initiate . . . .
::::Sir Bill . . . .
::::Clarification please . . . . . . wheeeeeeeeech slug ? . . . .as there are potentially 2 slugs each in the IF transformateurs along with 2 in
::::the ratioless- detecticatorating T-tormer.
::::The RF front ends L4 and osc L4 are air would coils and thereby dependent upon compressing or "knifing" their inductive values.
::::Thereby, being very low inductance and no needed use of associative slugs.
::::How's about taking another analytical path initially . . . . with it being in the respect of checking out that FM detector stages 2 ufd summing capacitor C2 to
::::see if time hasn't taken a toll on its electrolyte and is now currently residing waaaaay down in the .1 ufd range.
::::Additionally, is the power supply "healthy" . . . . . and having in the order of its prescribed ~ 130VDC at the plate of the 35C5 tube ?
::::Also is the 19T8's 220 K plate load resistor and its 4.7 meg grid resistors being within tolerances?
::::Also its . . . and the other tubes screen and plate voltage levels. ?
::::Also, if you don't happen to have another 19T8 to sub in to evaluate its detector diode sections, pull out a pair of modern day small signal
::::"computer switching" diodes of the 1N4148 0r 1N914 genus and solder tack across the 19T8.
::::They are as common as dirt in new electronics from the ~70's or even RS has them.
::::One diodes cathode will be going to pin # 3 and its anode to # 2.
::::The other diodes cathode will be going to pin # 7 and its anode to # 1.
::::Those are just my initial thoughts . . . check 'em out .
::::73's de Edd
::::The man who can smile when things go wrong has just thought of someone he can blame it on.
:::::::::Bill,
:::::::::What is the difference between models 610 and 610U ?
:::::::::I can provide the Photofact for model 610 (six tube FM only tabletop)however I can find no documentaion for a 610U.
:::::::::Dennis
:::::::::I don't know if there is a difference. I was using the model number of a picture of my radio. It may refer to the color of the cabinet. Thanks for any help.Bill
::::::::Dennis,
::::::::I have a photofact set 283 folder 6. It is marked Granco 610. The back of my radio says 610U. May mean the color of the case? I just included it in the model #.
::::::::Tony
::::::::My E-mail is bandsgee@cmaaccess.com
::::::Bill
:::::::I want to thank Tony and Dennis for their help. I have the radio playing now but the small tuning slug is broken. How should I proceed? Some of it is still in the tube.Volume is low. Is that due to slug?
:::::Bill
::::::Edd,
:Thanks for replying. I may have to have an interpreter but I think I get most of your comments. I checked the voltage at SR and have 105volts instead of 135. The plate voltages to V1,2,3,4 tubes is 68 instead of 80. Think the filtercaps are bad?
:Earlier,I was trying to say the tuning rod made out of glass or ceramic is broken where it attaches to the plastic mounting holder thing.
:I guess you have already concluded I am new to radio and need a lot of learning.
:Thanks for your help.
If you still want a picture, E-mail me and I'll send it.
Take care
Bill
:Sir Bill. . . .
:Ahhhhhhhhhh Soooooooooo . . . . with your most honnable info . . .and evaluating it, seems like you just might have have found yourself what is called a
:a piston variable capacitor.
:BUT the SAMS page 3 photo is too poor for me to be able to differentiate it out in the possible area it is used . . . near osc coil L4, possibly as capacitor adjustment A7. It possibly might even be a glass cylinder with L4 being a spiraled flat ribbon wire wound around it, for its required 2 or 3 turns of created inductance.
:The metal piston "slug" will be internal of the glass tubing and is adjusted with a threaded screw which drives it laterally.
:Can you get a digital closeup photo for confirmation ?
:Also that sel rectifier should be your low B+ problem and needs a 1N4007 silicon diode totally replacing it. . . . no mo' SR.
:Also filters may be in order after 50 years of time.
:Your volume and performance should come up appreciably after that.
:A 1N4007's increased B+ output will require some raising of R22's ohmic value to set the B+ back down to its initial value with the old SR being initially used.
:Why Athletes Can’t Have Regular Jobs:
:Upon his hearing of Joe Jacobi of the Redskin’s say:
:“I’d run over my own mother to win the Super Bowl,”
:Matt Millen of the Raiders said: “To win, I’d run over Joe’s Mom, too.”
:::Bill:
:::Your final post failed to initiate . . . .
:::::Sir Bill . . . .
:::::Clarification please . . . . . . wheeeeeeeeech slug ? . . . .as there are potentially 2 slugs each in the IF transformateurs along with 2 in
:::::the ratioless- detecticatorating T-tormer.
:::::The RF front ends L4 and osc L4 are air would coils and thereby dependent upon compressing or "knifing" their inductive values.
:::::Thereby, being very low inductance and no needed use of associative slugs.
:::::How's about taking another analytical path initially . . . . with it being in the respect of checking out that FM detector stages 2 ufd summing capacitor C2 to
:::::see if time hasn't taken a toll on its electrolyte and is now currently residing waaaaay down in the .1 ufd range.
:::::Additionally, is the power supply "healthy" . . . . . and having in the order of its prescribed ~ 130VDC at the plate of the 35C5 tube ?
:::::Also is the 19T8's 220 K plate load resistor and its 4.7 meg grid resistors being within tolerances?
:::::Also its . . . and the other tubes screen and plate voltage levels. ?
:::::Also, if you don't happen to have another 19T8 to sub in to evaluate its detector diode sections, pull out a pair of modern day small signal
:::::"computer switching" diodes of the 1N4148 0r 1N914 genus and solder tack across the 19T8.
:::::They are as common as dirt in new electronics from the ~70's or even RS has them.
:::::One diodes cathode will be going to pin # 3 and its anode to # 2.
:::::The other diodes cathode will be going to pin # 7 and its anode to # 1.
:::::Those are just my initial thoughts . . . check 'em out .
:::::73's de Edd
:::::The man who can smile when things go wrong has just thought of someone he can blame it on.
::::::::::Bill,
::::::::::What is the difference between models 610 and 610U ?
::::::::::I can provide the Photofact for model 610 (six tube FM only tabletop)however I can find no documentaion for a 610U.
::::::::::Dennis
::::::::::I don't know if there is a difference. I was using the model number of a picture of my radio. It may refer to the color of the cabinet. Thanks for any help.Bill
:::::::::Dennis,
:::::::::I have a photofact set 283 folder 6. It is marked Granco 610. The back of my radio says 610U. May mean the color of the case? I just included it in the model #.
:::::::::Tony
:::::::::My E-mail is bandsgee@cmaaccess.com
:::::::Bill
::::::::I want to thank Tony and Dennis for their help. I have the radio playing now but the small tuning slug is broken. How should I proceed? Some of it is still in the tube.Volume is low. Is that due to slug?
::::::Bill
:::::::Edd,
::Thanks for replying. I may have to have an interpreter but I think I get most of your comments. I checked the voltage at SR and have 105volts instead of 135. The plate voltages to V1,2,3,4 tubes is 68 instead of 80. Think the filtercaps are bad?
::Earlier,I was trying to say the tuning rod made out of glass or ceramic is broken where it attaches to the plastic mounting holder thing.
::I guess you have already concluded I am new to radio and need a lot of learning.
::Thanks for your help.
If any question, do the SAMS alignment with a meter . . no scope required . . . as per the first two parts of alignment info given. The other old question, was the use of an additional series resistor to compensate for the higher DC voltage output of a silicon diode |
:::::Bill,
:::::Dennis
::::Dennis,
::::Tony
::Bill
:::It has been quite a while since I heard anything new. I have found a glue that is supposed to adhere to glass and metal so I glued the small broken tuning slug to the control arm. So far it is holding. I have a garbled sound on both sides of a tuned station. I read about some caps inside the signal xformers but can't find any information as to the values needed. If i am thinking right, the poor contact in the cans will be the problem with tuning.
:Bill
: : : : ![]() : : : : : : : :Sir Bill . . . . : : : :I read about some caps inside the signal xformers but can't find any information as to the values needed. If i am thinking right, the poor contact in the cans will be the problem with tuning. : : : :Hold off on suspicioning any caps in IF transformers as being the fault.
: : : : : :The easiest way to find something lost around the house is to buy a replacement. : : : ![]() : : : |
