Distortion (prior to your re-cap) can be caused by a leaky capacitor in the AVC circuit, which reduces AVC voltage and prevents it from reducing RF amplifier sensitivity during reception of strong signals. Leaky audio coupling capacitors can also cause distortion, but the distortion will be present for all signals at all volume levels, and will most likely be present even when the radio is operated below normal voltage.
:You may have the electrolytics in backwards? All electrolytics in this radio should have their positives facing the rectifier cathode (or the field coil, which is connected to the rectifier cathode).
:Distortion (prior to your re-cap) can be caused by a leaky capacitor in the AVC circuit, which reduces AVC voltage and prevents it from reducing RF amplifier sensitivity during reception of strong signals. Leaky audio coupling capacitors can also cause distortion, but the distortion will be present for all signals at all volume levels, and will most likely be present even when the radio is operated below normal voltage.
:T.
I always understood that they would blow up if wired in reverse. (Thankfully, I never experienced this.)
:You probably have the electrolytics wired in backwards. Check them.
:T.
The positives should face the rectifier cathode and the field coil.
Also, be sure that the electrolytics are rated above the voltage seen in the radio's B circuit. If they are not rated high enough, it is possible that they operated ok with the lower voltage, but then began to break down once the voltage was increased. The break-down process can also occur over a period of time with full voltage, and might not happen right away. Either way, whether the electrolytics be reverse biased or rated inadequately voltage-wise, they can either explode or cause the rectifier plates to glow, or both.
:....Well, if the rectifier doesn't glow and blow up first.
:The positives should face the rectifier cathode and the field coil.
:Also, be sure that the electrolytics are rated above the voltage seen in the radio's B circuit. If they are not rated high enough, it is possible that they operated ok with the lower voltage, but then began to break down once the voltage was increased. The break-down process can also occur over a period of time with full voltage, and might not happen right away. Either way, whether the electrolytics be reverse biased or rated inadequately voltage-wise, they can either explode or cause the rectifier plates to glow, or both.
:T.
:Thomas, I double checked and I have the electrolytics installed with correct polarity. The fact that a 6X5 (using one side) has been wired in the replace the 1V, coul that be a factor in drawing too much?
::....Well, if the rectifier doesn't glow and blow up first.
::The positives should face the rectifier cathode and the field coil.
::Also, be sure that the electrolytics are rated above the voltage seen in the radio's B circuit. If they are not rated high enough, it is possible that they operated ok with the lower voltage, but then began to break down once the voltage was increased. The break-down process can also occur over a period of time with full voltage, and might not happen right away. Either way, whether the electrolytics be reverse biased or rated inadequately voltage-wise, they can either explode or cause the rectifier plates to glow, or both.
::T.
