rca 27664 codes for vertical alignment
10/15/2000 2:06:38 AMdon
Does anyone have the service codes for a rca model 27664 television so the vertical alignment can be centered
thanks
Don
10/15/2000 9:30:25 PMJohn McPherson
Sams
www.samswebsite.com
or
Anatek
www.anatek.com
Are your two best chances.
: Does anyone have the service codes for a rca model 27664 television so the vertical alignment can be centered
: thanks
: Don
10/25/2000 9:27:52 PMgg
: thanks
: Don
i have a photofact for model f27632sefe1
parameter parametername valuerange comment
00 pass no for service 76 must set to 76
05 vertical dc 00-15 adjust to center
10/25/2000 9:47:09 PMgg
: thanks
: Don
warning about parameter 01 horizontal frequency value range 00-63 if adjusting the horizontal frequency be careful not to exceed the value range , or the set will go into shutdown , and replacement of U3101 may be required !!!!
