Eico 666-08 Roll Chart
3/1/2008 12:23:58 AMKen
I have a Eico 666 Tube Tester and the roll chart is torn down the middle. Into three pieces two is on one roll and one piece is on the other roll. I'm in need of another roll chart bad the model is 666-08.
3/1/2008 11:54:30 PMplanigan
Ken, bama and the mirror site (see bama for address) have a 666-05 [not sure of 5 but is earlier than your 8] You can down load it and see if its in the proper spacing. If so you can take the program to KINKO's and they will print it out on a continuous sheet and will cut it to proper length. About $15. PL
:I have a Eico 666 Tube Tester and the roll chart is torn down the middle. Into three pieces two is on one roll and one piece is on the other roll. I'm in need of another roll chart bad the model is 666-08.
