Restoring a Bakelite Finish
2/29/2008 10:25:35 PMMike Dice
I need some help. I am restoring an RCA model 510 Radiola. Last weekend I "cleaned" the bakelite cabinet with comet and a toothbrush. Now it is very clean, and all the finish is gone. The cabinet is in excellent physical condition (no cracks or scratches). I need to know what product and procedure to do to restore the shiny finish again.
2/29/2008 10:39:55 PMGeorge
Hi, this may sound a little weird but try some black or brown shoe polish. Rub it on and buff it off before it dries. I have had really good results with it.
2/29/2008 11:33:30 PMMike
:Hi, this may sound a little weird but try some black or brown shoe polish. Rub it on and buff it off before it dries. I have had really good results with it.
Thanks for the advice George. I'll give it a try.
3/1/2008 3:09:50 PMBill G.
Hi Mike and George,
I use neutural shoe polish, so the original color is retained. That works well for me. I have also heard using brasso for the cleaning, too, on this forum.
Best Regards,
Bill Grimm
3/1/2008 6:39:45 PMPeter G. Balazsy
Before the shoe polish I first use Brasso and rub it on like you would compound your car.
It will reward you with a GREAT lasting shine.
Brasso has been recognized now by most of us as the real solution.
Sometimes I will also add some butchers wax or shoe polish as a finishing coat.
Try it... but remember to rub it on well... let dry a bit and buff it out by hand... Brasso is the key to restoring Bakelite.
3/2/2008 1:26:07 AMGeorge
Hi Mike, if you are new at this hobby you might want to check into Bret's Old Radios DVD set. It is a set of 4 DVD's on refinishing and electronics. They cover bakelite, plastic, plankstan, and wood. They also cover the electronics from the 1930's to the 60's. I got the hole set for 19.95 a disk. They have really helped me and are worth thier weight in gold. bretsoldradios@att.net Have Fun, George.
3/8/2008 12:15:34 AMMike
:Before the shoe polish I first use Brasso and rub it on like you would compound your car.
:It will reward you with a GREAT lasting shine.
:Brasso has been recognized now by most of us as the real solution.
:Sometimes I will also add some butchers wax or shoe polish as a finishing coat.
Peter,
I used the brasso along with a coat of neutral shoe polish and a lot of elbow grease. Now it looks better than when I got the radio. Thanks!
Mike
:Try it... but remember to rub it on well... let dry a bit and buff it out by hand... Brasso is the key to restoring Bakelite.
3/10/2008 8:34:35 AMBill G.
Thank you for the tip, Peter, I will try Brasso next time.
The radio I am restoring now is wooden.
Best Regards,
Bill Grimm
3/8/2008 12:13:15 AMMike
:Hi Mike and George,
: I use neutural shoe polish, so the original color is retained. That works well for me. I have also heard using brasso for the cleaning, too, on this forum.
:Best Regards,
:Bill Grimm
Bill,
I used the brasso followed by neutral shoe polish along with a lot of elbow grease. Now it looks better than when I got the radio. Thanks!
Mike
3/9/2008 7:48:02 PMjohn
:I need some help. I am restoring an RCA model 510 Radiola. Last weekend I "cleaned" the bakelite cabinet with comet and a toothbrush. Now it is very clean, and all the finish is gone. The cabinet is in excellent physical condition (no cracks or scratches). I need to know what product and procedure to do to restore the shiny finish again.
Never,never,never use abrasive cleaners like ajax,comet and or a tooth brush for that matter.Never use detergent cleaners also. This will for the most part take away the natural shine of the baklite finish for good. To clean baklite use a mild solution like Simple Green sold in most True Value stores or a non detergent soap with a SOFT sponge to take away and dirt or stains. Follow this up with what I have found to be very effective spray and buff solution called by the name of Magnolia Glayzit Telephone Refinisher sold by Radio Daze also might try Antique Electric. Use a soft cloth to buff it in until dry.
This method will give great reults to OTHER radios you might clean. For the radio you have alreay cleaned with comet I guess you can try using shoe polish method to try to get back some of the luster.
