:I have a philco 40-195. As I am recapping, I took out a couple capacitors that are labeled as 1000 working voltage. Do they really need to be that high a voltage? These are on the lines feeding the output transformer items 72 and 75 on the schmatic.
:In looking at the schematic there is about 215V across the caps. I've personally been purchasing 630 WVDC caps for recapping and haven't run into a problem yet. I wouldn't think you would need to put 1000 WVDC caps back in, unless I'm mistaken.
::I have a philco 40-195. As I am recapping, I took out a couple capacitors that are labeled as 1000 working voltage. Do they really need to be that high a voltage? These are on the lines feeding the output transformer items 72 and 75 on the schmatic.
: I'm not to sure that you shouldn't try to replace them with 1000 volters. It's not so much the "normal" operating voltage but the spikes that can occur from static etc. PL
::In looking at the schematic there is about 215V across the caps. I've personally been purchasing 630 WVDC caps for recapping and haven't run into a problem yet. I wouldn't think you would need to put 1000 WVDC caps back in, unless I'm mistaken.
:::I have a philco 40-195. As I am recapping, I took out a couple capacitors that are labeled as 1000 working voltage. Do they really need to be that high a voltage? These are on the lines feeding the output transformer items 72 and 75 on the schmatic.
Best Regards,
Bill Grimm
:Hi All,
: I agree with Robert on the voltage rating due to the AC on the DC voltage. However, putting capacitors in series is an unreliable practice. The problem is that the capacitor that has the lesser leakage will take more voltage.
: See page 1694 on the Digi-Key catalog, www.digikey.com. You will find plenty of HV capacitors.
:Best Regards,
:Bill Grimm
