Aligning the IF stages went well:
My problem seems to be with the Discriminator, I can't seem to get a nice symmetrical waveform. This is the best I can get with the 10.7 marker pip right where the waveform crosses the baseline:
Since I replaced the caps in the discriminator can, I'm wondering if I did something wrong in there, though I did double check my wiring & it all looks OK. Any ideas?
Thanks, Mark.
I have aligned several radios and recorded the reading when an unmodulated carrier was tuned from 9.7 MHz to 11.1 MHz. The negative peak was -0.808, the positive 0.547. I had some asymmetry, but not like your scope is showing.
Have you injected the signal at the grid of the limiter? If not, try that.
Best Regards,
Bill Grimm
:Hi Mark,
: That is a nifty set up. I have been trying to do that, but my WWII veteran FM signal generator doesn't have an audio output. By the way I do not recommend using vintage test equipment. I could have restored three radios with the effort I put into getting that piece of junk going.
: I have aligned several radios and recorded the reading when an unmodulated carrier was tuned from 9.7 MHz to 11.1 MHz. The negative peak was -0.808, the positive 0.547. I had some asymmetry, but not like your scope is showing.
: Have you injected the signal at the grid of the limiter? If not, try that.
:Best Regards,
:Bill Grimm
