Yes, you can. A #42 tube has a max plate current of about 35mA. Using the formula P=I squared x R :
(.035x.035)x 750 = .91875 Watts. Therefore, a 1 watt resistor should suffice. Nothing wrong with a 2 or 3 watt if you have one. Watch out that the tube is not shorted or the new reistor could smoke!
Plate current for 2A5 is the same.
::Bob
::::Can I replace a 2 inch cloth covered 750 ohm wirewound resistor with a conventional resistor? It has
::::solid wire-wound ends with cloth in between. I accidentally broke it as it was very brittle. What wattage would be needed in the replacement also. This is in a Crosley 148.
::::Thanks, Bob
:::Yes, you can. A #42 tube has a max plate current of about 35mA. Using the formula P=I squared x R :
:::(.035x.035)x 750 = .91875 Watts. Therefore, a 1 watt resistor should suffice. Nothing wrong with a 2 or 3 watt if you have one. Watch out that the tube is not shorted or the new reistor could smoke!
:Plate current for 2A5 is the same.
:::This set has a 2A5 in place of a #42 in contrast to what the schematic says. I cannot find the correct schematic. So I guess the 2A5 would be about the same?
:Robert,
:What reference do you use to find the plate current for tubes? And thanks for responding to my question. I appreciate it very much.
:Bob E
:::Bob
:::::Can I replace a 2 inch cloth covered 750 ohm wirewound resistor with a conventional resistor? It has
:::::solid wire-wound ends with cloth in between. I accidentally broke it as it was very brittle. What wattage would be needed in the replacement also. This is in a Crosley 148.
:::::Thanks, Bob
::::Yes, you can. A #42 tube has a max plate current of about 35mA. Using the formula P=I squared x R :
::::(.035x.035)x 750 = .91875 Watts. Therefore, a 1 watt resistor should suffice. Nothing wrong with a 2 or 3 watt if you have one. Watch out that the tube is not shorted or the new reistor could smoke!
::Plate current for 2A5 is the same.
