Jim: chances are that it had the dreaded transformer melt-down from a defective 6X5G recifier tube which were prone to have heater to cathode shorts. I think this problem is more prevalent with dual 6X5's however. The newer 6X5GT's with an "X" shaped plates are better in that regard. It would be wise to install a fuse to protect the transformer when you find a replacement, and use a CL-90 current limiter on the transformer primary leads to limit the inrush current at turn-on. It looks like the 6X5G needs 275 vac on the plates, and 6.3 v for the filament. Radiodaze.com should have what you need. You'll have to match up the physical dimentions and style to fit your radio.
Steve
How can you tell that the 6X5G needs 275 Vac on the plates?
Mike Nealon
The RCA tube manual shows that a 6X5 should have a maximum plate voltage of 325VAC (with a capacitive input filter). Zenith is calling for 275VAC.
Doug
:::I have a bad transformer in a Zenith 7s633 I purchased on e-bay. very good condition but the transformer is shot. Anyone know a resource to purchase a tranformer?
::Jim: chances are that it had the dreaded transformer melt-down from a defective 6X5G recifier tube which were prone to have heater to cathode shorts. I think this problem is more prevalent with dual 6X5's however. The newer 6X5GT's with an "X" shaped plates are better in that regard. It would be wise to install a fuse to protect the transformer when you find a replacement, and use a CL-90 current limiter on the transformer primary leads to limit the inrush current at turn-on. It looks like the 6X5G needs 275 vac on the plates, and 6.3 v for the filament. Radiodaze.com should have what you need. You'll have to match up the physical dimentions and style to fit your radio.
::Steve
:How can you tell that the 6X5G needs 275 Vac on the plates?
:Mike Nealon
:Here's the schematic, which shows each plate at 275VAC. Since this is a full-wave rectifier, the plate-to-plate voltage would be 2x275 = 550VAC. A replacement power xfmr should have a center-tapped secondary winding approximately equal to that voltage.
:The RCA tube manual shows that a 6X5 should have a maximum plate voltage of 325VAC (with a capacitive input filter). Zenith is calling for 275VAC.
:Doug
::::I have a bad transformer in a Zenith 7s633 I purchased on e-bay. very good condition but the transformer is shot. Anyone know a resource to purchase a tranformer?
:::Jim: chances are that it had the dreaded transformer melt-down from a defective 6X5G recifier tube which were prone to have heater to cathode shorts. I think this problem is more prevalent with dual 6X5's however. The newer 6X5GT's with an "X" shaped plates are better in that regard. It would be wise to install a fuse to protect the transformer when you find a replacement, and use a CL-90 current limiter on the transformer primary leads to limit the inrush current at turn-on. It looks like the 6X5G needs 275 vac on the plates, and 6.3 v for the filament. Radiodaze.com should have what you need. You'll have to match up the physical dimentions and style to fit your radio.
:::Steve
::How can you tell that the 6X5G needs 275 Vac on the plates?
::Mike Nealon
