:Can anyone e-mail me a schematic for an Automatic Radio model 920 I can't find one
:Thanks
:Tom
:What age would you guesstimate it to be and what tube lineup ?
:Ed
::Can anyone e-mail me a schematic for an Automatic Radio model 920 I can't find one
::Thanks
::Tom
:: Tom- That Tuning eye tube would be a 6U5/6G5 type.
:They list some models with a similar tube line-up,but without the Tuning eye(4 tube models).The schematics may be similar otherwise. Make sure that they are superhet,like yours is. They are:B10,10LW,10P,15,20,D5,T,40,50,816 and 818. If you find one of these to compare with what you have,it may help you out. I'll post any info I find. Best of Luck. -Walt.
That is also certainly what I was thinking about, in the respect of a tuning eye tube being utilized in that set.
With two pentodes and an AF power tube along with the rectifier in the tube lineup, that certainly doesn’t
sound like needing the conjunct utilization of a tuning tube,
unless its was for more precise tuning indication on a
TRF set design.
Usually one only expects eye tubes on the top of the series sets, with up to ’lebenteen tubes in them.
How about looking at the tuning condenser and seeing how many sections that it has and if all sections
seem to be of the same value….a la TRF.
Also, is the tuning eye tube “officially” factory mounted with an
eye brow front bezel and typical mounting socket ?
: Tom- Your radio is listed as a superhet in the Radio Diagram Sourcebook,but that could be in error. They list the D5 as a TRF. The 6E5 is listed as a substitute for the 6U5/6G5,so you should be OK there. No luck on schematic data for the 920 yet. -Walt.
:: Tom- Your radio is listed as a superhet in the Radio Diagram Sourcebook,but that could be in error. They list the D5 as a TRF. The 6E5 is listed as a substitute for the 6U5/6G5,so you should be OK there. No luck on schematic data for the 920 yet. -Walt.
