Start with fresh electrolytics. It is possible that you ruined the ones you are using currently. They cannot be installed backwards.
:The rectifier cathode is always the most positive part of the set. Both of the electrolytics' positives should go to the rectifier cathode. One negative should go on one side of the field coil, and the other goes to the other side of the field coil, as indicated in the schematic.
:Start with fresh electrolytics. It is possible that you ruined the ones you are using currently. They cannot be installed backwards.
:T.
I saw you hanging….stymied…. there also :
<" Ok I guess Im rusty at this but solid state diodes, isnt the cathode the negative and the anode positive?
On the typical solid state diode, the band / ring / dot referenced lead is the CATHODE and it would be the source of your + DC voltage if fed with raw AC into its other ANODE lead.
I’m looking at the two schematics on the page….. and you said that the top one was your "R" series unit… I do see the handling of the G2 ad G3 circuitry of the “Simple” little receiver and with nothing varying from the norm in the bypassing / decoupling actions of those .1ufd units.
Some manufacturers larger sized capacitors did sometimes have mounting straps around them, particularly, if used in a mobile environment like the military, where their mass , if left floating could result in vibrationally broken leads. I assume that they had the strap grounded with a screw or rivet and possibly the lead that would have went to ground…was soldered to that strap ?
The only other application special to a cap of that mechanical dimensions that I can remember is where there is a coil wound around a portion of the outside of the cap with several turns of wire, and then connected to one end of the cap with the other end of the coil wire going to ground.
That just mentioned cap is usually in the order of decimal 001ufd and the series inductor made with the wire results in a series L/C trap coil that shunts potentially bothersome low frequency signals from NAVTEK, GWEN and NAVBEACON transmissions .
I don’t think that you have that situation on your chassis, with a series RF attenuation trap built as I mentioned.
As well, your low mechanical mass replacement caps definitely should not need mechanical support.
:Sean,
:I was just reading thru your problem with the old cap. One of the things I find with my old RCA victrola 612V3 is that there is unusual things done long ago that have long since disolved into the ether. I have also found, try it without, because most of these circuits aren't that critical. Sounds like some type filtering aftermarket fix by the manufacturer. Your guess is sound grasshopper.
:Regards
:Steve
Hmmmm....I'm getting tired, and I'm not quite sure where I"m going anymore. Hope this helps.
::Ok translation, I should not stop working on radios so I wont forget how to replace caps. Ok I guess Im rusty at this but solid state diodes, isnt the cathode the negative and the anode positive?
::The rectifier cathode is always the most positive part of the set. Both of the electrolytics' positives should go to the rectifier cathode. One negative should go on one side of the field coil, and the other goes to the other side of the field coil, as indicated in the schematic.
::Start with fresh electrolytics. It is possible that you ruined the ones you are using currently. They cannot be installed backwards.
::T.
