http://www.nostalgiaair.org/resources/S00000026%20NORTHERN%20ELECTRIC.htm
Ken
They should have kept the old files active.
The resolution is much better than most actual schematics. Just an observation.
The old Riders gif's are still there and are archived by Volume as in following link.
http://www.nostalgiaair.org/resources/r00000001.htm
To access the later volumes change the number 1 after the last 0 before .htm to a number up to 9 and drop that last zero and change that to 1 or 2 for the volumes after nine as in.
http://www.nostalgiaair.org/resources/r00000023.htm
As for that test post (KW) I was just trying to figure how A Valid Name escaped the box. 80)
Thanks for the hint ! As for escaping the box you must think "outside the box" 8o).
A previous poster made an involuntary goof while posting, with the result you see here. I just had a look at the HTML source and found the reason within seconds ( I teach HTML/PHP ). HTML adopts strange -and interesting- behaviour when used improperly"....
Seems to me that:
"HTML adopts strange -and interesting- behaviour when used improperly"....
also when used properly sometimes.
Am I back in the box????
:: I posted the link for Brian since I didn't see the pdf for the 552 listed presently under the Northern Electric schematics in Resources.
:::The old Riders gif's are still there and are archived by Volume as in following link.
::: http://www.nostalgiaair.org/resources/r00000001.htm
:::To access the later volumes change the number 1 after the last 0 before .htm to a number up to 9 and drop that last zero and change that to 1 or 2 for the volumes after nine as in.
::: http://www.nostalgiaair.org/resources/r00000023.htm
:::As for that test post (KW) I was just trying to figure how A Valid Name escaped the box. 80)
::A previous poster made an involuntary goof while posting, with the result you see here. I just had a look at the HTML source and found the reason within seconds ( I teach HTML/PHP ). HTML adopts strange -and interesting- behaviour when used improperly"....
:Seems to me that:
:"HTML adopts strange -and interesting- behaviour when used improperly"....
:also when used properly sometimes.
:Lewis
Brian I have the Origional Northern Electric Service Bulletin for that radio. If you give me your email address I can scan it and send it to you. Its three pages and also covers the model 550.
Gerald
