I, and many others, have never run into trouble when using an electrolytic that's rated much higher than the voltages encountered in the circuit it is used in. I would not be surprised if the electrolytic could later be used in a circuit in which the voltage is near its maximum rated value.
Ralph: original specs were for 150v filter caps, so as Thomas has pointed out, 160's are just fine. TO's aren't really that finickey about capacitance values on filter caps either. Instead of 60, 40, and 20 mfd, I used three 47's with radial leads on a terminal strip on my L600 and it works perfectly. You can see the same method on Joe Urbanovitch's website: http://www.radiosphonos.com/store/prodimg/tochassis/
Steve
