The filter caps are probably in need of replacement, and would be the first things I would replace before even firing it up for that test. If you get the same results, and "B" voltages present, I would concentrate on the Horizontal and HV sections.
: I have a 1950's metal 10" portable TV model # TS103N that only will light the tubes, no sound, no picture. Any idea on where a schematic is available and how to start to restore this aqua/and white 1950's classic? Thanks
Hope this helps.
Tim
: Hope this helps.
: Tim
