The service data is here:
http://www.nostalgiaair.org/PagesByModel/866/M0018866.pdf
If you haven't already, you could try substituting one of the 78s in the IF for the det/osc 78.
:Hello All,
: As usual, I have replaced all the paper and filter capacitors. I have also replaced the line resistor with a 126 ohm power resistor. I used a 500 ohm 225W adjustable resistor and have it set to 126 ohms. It runs very warm to the touch but it cannot burn the skin. This resistor works beautifully.
: Anyway BC works perfectly but when I switch to Short Wave there is silence. I think I have the band switch cleaned. What else may I have overlooked? Could it be that the 78 can no longer oscillate at the SW frequencies?
:Thanks,
:Dave
:The service data is here:
:http://www.nostalgiaair.org/PagesByModel/866/M0018866.pdf
As someone else mentioned, try another oscillator tube. They usually stop operating on higher frequencies first.
:Dave,
:If you haven't already, you could try substituting one of the 78s in the IF for the det/osc 78.
:Radiodoc
::Hello All,
:: As usual, I have replaced all the paper and filter capacitors. I have also replaced the line resistor with a 126 ohm power resistor. I used a 500 ohm 225W adjustable resistor and have it set to 126 ohms. It runs very warm to the touch but it cannot burn the skin. This resistor works beautifully.
:: Anyway BC works perfectly but when I switch to Short Wave there is silence. I think I have the band switch cleaned. What else may I have overlooked? Could it be that the 78 can no longer oscillate at the SW frequencies?
::Thanks,
::Dave
::The service data is here:
::http://www.nostalgiaair.org/PagesByModel/866/M0018866.pdf
Thanks for your help,
:Dave
: As someone else mentioned, try another oscillator tube. They usually stop operating on higher frequencies first.
::Dave,
::If you haven't already, you could try substituting one of the 78s in the IF for the det/osc 78.
::Radiodoc
:::Hello All,
::: As usual, I have replaced all the paper and filter capacitors. I have also replaced the line resistor with a 126 ohm power resistor. I used a 500 ohm 225W adjustable resistor and have it set to 126 ohms. It runs very warm to the touch but it cannot burn the skin. This resistor works beautifully.
::: Anyway BC works perfectly but when I switch to Short Wave there is silence. I think I have the band switch cleaned. What else may I have overlooked? Could it be that the 78 can no longer oscillate at the SW frequencies?
:::Thanks,
:::Dave
:::The service data is here:
:::http://www.nostalgiaair.org/PagesByModel/866/M0018866.pdf
I had a similar problem on a Model 580, which was manufactured around the same time. It turned out to be an open osc coil on SW1 band.
Gary
:Hello All,
:Thanks,
:Dave
