OR..how you crazee Amerikanskis say.....This is do-it-ALL-yourself....to the ultimate degree.
You just KNOW that you want to see that ...right?
With just a tad of voice / audio at its very ends regenerative receiver trials.
All home made glass turning lathe, glass envelopes,tube elements, tube mechanical infrastructure, jigs, spot welder,
evacuation vacuum pump, vacuum instrumentation, kiln, RF induction heater,tube characteristics performance plotter,
yada..yada..yada...and the beat goes on.
Here 'tis.... all hot linked up fer ye:
http://dailymotion.alice.it/video/x3wrzo_fabrication-dune-lampe-triode_tech
:Yep, saw that one. The ultimate electronics hobbyist. Love that little benchtop spot-welder. Any idea what that "clamshell" gizmo is ? (The one with the white innards where he hangs the tubes and the encloses them)
All I can say is, "Thank goodness for Radio Daze!" hehehe
Paul
:C'est "le font vous-même" au degré final.
:OR..how you crazee Amerikanskis say.....This is do-it-ALL-yourself....to the ultimate degree.
:You just KNOW that you want to see that ...right?
:With just a tad of voice / audio at its very ends regenerative receiver trials.
:All home made glass turning lathe, glass envelopes,tube elements, tube mechanical infrastructure, jigs, spot welder,
:evacuation vacuum pump, vacuum instrumentation, kiln, RF induction heater,tube characteristics performance plotter,
:yada..yada..yada...and the beat goes on.
:Here 'tis.... all hot linked up fer ye:
:http://dailymotion.alice.it/video/x3wrzo_fabrication-dune-lampe-triode_tech
Edd: Wouldn't that be "le fait vous-meme" au degre final." ??
"Faites le vous-même. Version ultime." ou encore:
"Faites le vous-même à l'exposant 10".
Les engins de traduction en ligne ne valent pas cher.
