Zenith AM-FM alignment question
1/18/2008 7:51:17 PMMmakazoo
Hi, all: I am looking at the instructions for my Zenith model Y832E regarding the FM alignment. Several of the steps indicate "adjust for maximum deflection". What exactly does this mean? Mark from Kalamazoo
1/18/2008 8:25:37 PMMarv Nuce
Mark,
Probably referring to the meter deflection on a VTVM, where absolute value is not important. May be referring to AM IF alignment where a peak of the narrow IF response curve is correct, but for FM IF alignment a sweep gen is req'd to shape/tune the response curve to the wider req'ts of FM IF. I've never tried it, but suspect using a VTVM and peaking an FM IF for max deflection, would lose most of the information, severe distortion and drive the AGC circuit crazy.
marv.
:Hi, all: I am looking at the instructions for my Zenith model Y832E regarding the FM alignment. Several of the steps indicate "adjust for maximum deflection". What exactly does this mean? Mark from Kalamazoo
1/18/2008 8:47:36 PMMmakazoo
Marv: The alignment instructions include both using an AM signal generator/VTVM and FM signal generator/oscilloscope. It's in the section for using an AM signal generator that includes the adjust or maximum deflection comment. Mark from Kalamazoo
1/18/2008 10:40:45 PMMarv Nuce
Mark,
Some of the earlier/cheaper FM sig gens had an output for the horiz sweep on the scope, and when used in conjunction, created a sweep gen sys. for FM IF alignment. Later on, spectrum analyzers came into the spotlight, and provided both the scope and sweep functions. I loved it (Marconi 2350???) with digital display. No blooming or phosphor burns.
:Marv: The alignment instructions include both using an AM signal generator/VTVM and FM signal generator/oscilloscope. It's in the section for using an AM signal generator that includes the adjust or maximum deflection comment. Mark from Kalamazoo
