:Hi everyone. I have a Temple trf set with 4 rf coils. I have recapped rewired and resoldered everything. Replaced both audio interstage transformers.Plate voltages etc all seem within specs.Tested all tubes and replaced them even though tested like new. Volume controls test fine not finicky. I get intermittent volume from first rf tube all
:the way through the chain. Could it be faulty rf coil?
:Some green spots but coils test reasonable resistance.
:Touching grid of second tube seems to snap everything back into shape as long as its not insulated. Thanks Gordon
Leave no cap or resistor or wire overlooked. Go over all solder connections in the radio with fresh solder.
In my Crosley 148, sometimes the audio would pop in and out, especially when the set was turned upside down. Touching things would kick it back into action. I finally found that bumping the output tube made the most difference. Sadly the spot weld to the cathode lead had been burned thin right from the factory. The tube was probably always either faulty, or on the verge of being faulty, with only a slight vibration to crack the connection all the way through. Such a problem would of course show up at the cathode resistor of the output tube. I also had a type 27 tube with a faulty cathode connection in my Majestic 180. I had a very hard time finding the actual break, but it finally wouldn't work no matter how hard I bumped it, and sure enough, when tested, it tested at 0. Resoldering the pins did nothing to help.
.....You know........I've been thinking about this for a while. At first I was thinking that the set was breaking into oscillation, which still may be a possibility, though usually you'll get a squeel and a snap, and then there won't be much reception at all, if any.
The schematic above is for the 880. I can't find your schematic. I'll just have to assume that the 881 is similar, though it may not be. If you look at the schematic you'll notice 1000 ohm resistors in series with the grid part of each RF coil. If one of these was to open up or severely drift in value, the signal might make it to the grid via capacitance of the resistor, though the grid wouldn't be attached to bias in a solid manner, so bias might fluctuate at the grid, causing a change in volume. Touching the grid would discharge the stray bias, causing the tube to snap back into action.
If this is the case, measure resistance between the 2nd RF tube grid cap and the chassis. If not around 1000 ohms (assuming that your radio is like the 880....if not, let me know), then you have a fault either in the resistor or in some other connection. Check all other RF grids as well. If your set is like the 880, most of the RF grids should have 1000 ohms between them and the chassis (plus any resistance of the RF coil).
If your radio is like the 880, the volume control, unlike a lot of other TRFs, doesn't control cathode bias of the RF tubes. The RF tubes are simply set for maximum allowable gain, and that is that. The volume control only adjusts the amount of signal from the antenna. Since RF circuits are always operating at maximum gain, be sure that all shields are in place. All RF tubes should be shielded, and it might be a good idea to shield the coils, too. That is the best option, though they aren't always shielded. With the RF circuits not properly shielded, they can feed signals back at eachother, and can break into random oscillation.
Hopefully you have a schematic for your radio. Check all resistances against originals. If resistances are altered, biasing might be unstable (if, say, a resistor in a grid circuit was significantly increased in value), or the set could break into random oscillation (say, if cathode resistances are decreased, causing more gain).
.....Also, I notice a 10 ohm variable resistor (rheostat) in parallel with the plate coil of the 2nd RF tube (again, assuming that the 880 is like the 881). If that is faulty (dirty), it could cause volume fluctuations. Touching the 2nd RF grid might send enough of a surge through the rheostat to temporarily clear up the problem.
Perhaps check the resistors and transformers in the detector and audio circuits. An open resistor at the detector would allow the detector grid to saturate with electrons. Touching one of the RF grids might shock the detector back into operation....perhaps from static. You might also try turning the volume all the way up to see if you get the same result as touching the 2nd RF grid with your finger.
Open transformer secondaries in the audio circuit would allow grids to wander around as far as bias is concerned. At one point or another the grid connected to the problematic transformer would saturate with electrons, and amplification would decrease or cease all together. Distortion might accompany the other symptoms.
If your original volume control tested fine, then you can probably put it back into operation......if not now, then certainly after you have found your source of trouble.
Also we shouldn't rule out the bronze spring contacts that make between the stator and rotor of the tuning capacitor(s). Dirty contact(s) generally show up when tuning the capacitor. It is possible to cause trouble at other times.
:The 1K resistor that you say is at 1.1K is probably just fine.
:Perhaps check the resistors and transformers in the detector and audio circuits. An open resistor at the detector would allow the detector grid to saturate with electrons. Touching one of the RF grids might shock the detector back into operation....perhaps from static. You might also try turning the volume all the way up to see if you get the same result as touching the 2nd RF grid with your finger.
:Open transformer secondaries in the audio circuit would allow grids to wander around as far as bias is concerned. At one point or another the grid connected to the problematic transformer would saturate with electrons, and amplification would decrease or cease all together. Distortion might accompany the other symptoms.
:If your original volume control tested fine, then you can probably put it back into operation......if not now, then certainly after you have found your source of trouble.
:T.
