TRANS OCEANIC 8G005 ANTENNA MAST
1/14/2008 12:52:37 PMMark
Hi again!
Pardon all the Trans-Oceanic questions. I just purchased my first set, a H500 and I'm in the process of restoring it.
I need to replace the H500 antenna. The clip is missing.
Will a 8G005 antenna work on this set?
Thanks!
Mark
1/14/2008 4:40:49 PMRadiodoc
Mark,
You may check here:
http://www.radioera.com/zenithparts.asp
They have some parts for sale from parted out TOs. You can ask them a question and see if the part you need may be available.
:Hi again!
:Pardon all the Trans-Oceanic questions. I just purchased my first set, a H500 and I'm in the process of restoring it.
:I need to replace the H500 antenna. The clip is missing.
:Will a 8G005 antenna work on this set?
:Thanks!
:Mark
1/14/2008 4:47:13 PMMark
Hi Radiodoc!
I located a G8005 antenna. I was wondering if you can use it on a H500. My H500 antenna is missing the metal clip.
The 8G005 antenna I'm looking at has the clip.
Mark
1/27/2008 1:29:34 PMDave Froehlich
Mark,
If the top knob and spring still operate correctly, and the slot from the old metal strip is still intact, a new clip can be made out of a strip of aluminum cut from an aluminum sheet. I made one recently and it works great.
I hope that this helps,
:Hi Radiodoc!
:I located a G8005 antenna. I was wondering if you can use it on a H500. My H500 antenna is missing the metal clip.
:The 8G005 antenna I'm looking at has the clip.
:Mark
