12SK7 and 12SG7 are usually interchangeable. A 12J5 and 12H6 could be interchangeable if the tube is used as a detector? This tube will be using pins #5 and #8.
Around WW2 manufacturers used whatever tubes they could get. Not unusual for the same model to have different tubes.
Type of tubes are not causing a problem. Most likely a leaky cap?
:Hi, I have 2 different schematics for this radio and have a question about 2 of the tubes. In the Photo Fact schematic it says to use a 12SG7 semi remote cut off RF Pentode in socket #2 and a 12J5 Med Mu Triode in socket #3. In the other schematic John F. Rider it says to use a 12SK7 Remote Cut off Pentode in socket #2 and either a 12H6 Duo Diode or 12J5 in socket #3. The radio currently has the Rider schematic tubes in it the 12SK7 and the 12H6 both are metal tubes. There are a couple things I have to take care of one socket possibly is loose and a OOT resistor. Was kind of wondering if the tube configuration could be causing the problem with the static I'm getting after a hour or so of playing the radio. Thanks Again, George.
:Hi George
: 12SK7 and 12SG7 are usually interchangeable. A 12J5 and 12H6 could be interchangeable if the tube is used as a detector? This tube will be using pins #5 and #8.
: Around WW2 manufacturers used whatever tubes they could get. Not unusual for the same model to have different tubes.
: Type of tubes are not causing a problem. Most likely a leaky cap?
::Hi, I have 2 different schematics for this radio and have a question about 2 of the tubes. In the Photo Fact schematic it says to use a 12SG7 semi remote cut off RF Pentode in socket #2 and a 12J5 Med Mu Triode in socket #3. In the other schematic John F. Rider it says to use a 12SK7 Remote Cut off Pentode in socket #2 and either a 12H6 Duo Diode or 12J5 in socket #3. The radio currently has the Rider schematic tubes in it the 12SK7 and the 12H6 both are metal tubes. There are a couple things I have to take care of one socket possibly is loose and a OOT resistor. Was kind of wondering if the tube configuration could be causing the problem with the static I'm getting after a hour or so of playing the radio. Thanks Again, George.
