effect of connecting digital meter to chassis
1/11/2008 3:19:27 PMCharles
I notice something interesting when I attach the ground of my digital meter to the chassis of a battery set, running off a B volt eliminator. I believe the meter is loading? as volume decreases somewhat. Can someone explain what is happening here?
1/13/2008 8:31:04 PM--->
:I notice something interesting when I attach the ground of my digital meter to the chassis of a battery set, running off a B volt eliminator. I believe the meter is loading? as volume decreases somewhat. Can someone explain what is happening here?
1/13/2008 10:22:15 PMLewis L
::I notice something interesting when I attach the ground of my digital meter to the chassis of a battery set, running off a B volt eliminator. I believe the meter is loading? as volume decreases somewhat. Can someone explain what is happening here?
i have seen this before, and I think it might be caused by connecting an outside wire, acting like an antenna, only out of phase with the antenna collecting the signal you want.
