Motorola radio/phonograph identification
1/10/2008 7:50:36 AMPaul
:: Hello all! I am trying to identify a 17" cubed wooden-case Motorola AC radio/phonograph, probably from the 40s as it has a lot of inlaid embellishment and a tiger wood faux across the bottom. I will begin scanning through the lengthy list of resources, but if anyone could help shorten the time involved, it would be greatly appreciated. The tube line-up is:
6ABGT, 6SK7GT, 6V6GT, 65Q7GT & 5W4GT. It also has an Aero-Vane (I think that's what it was called) antenna mounted on the inside of the back cover. Thanks.
Paul
1/10/2008 7:55:26 AMPaul
:: Sorry, 6A8GT not 6ABGT
::: Hello all! I am trying to identify a 17" cubed wooden-case Motorola AC radio/phonograph, probably from the 40s as it has a lot of inlaid embellishment and a tiger wood faux across the bottom. I will begin scanning through the lengthy list of resources, but if anyone could help shorten the time involved, it would be greatly appreciated. The tube line-up is:
:6ABGT, 6SK7GT, 6V6GT, 65Q7GT & 5W4GT. It also has an Aero-Vane (I think that's what it was called) antenna mounted on the inside of the back cover. Thanks.
:Paul
1/10/2008 1:37:26 PMPaul
::: I found it...it's a 58-FRC! Thanks.
::: Sorry, 6A8GT not 6ABGT
:::: Hello all! I am trying to identify a 17" cubed wooden-case Motorola AC radio/phonograph, probably from the 40s as it has a lot of inlaid embellishment and a tiger wood faux across the bottom. I will begin scanning through the lengthy list of resources, but if anyone could help shorten the time involved, it would be greatly appreciated. The tube line-up is:
::6ABGT, 6SK7GT, 6V6GT, 65Q7GT & 5W4GT. It also has an Aero-Vane (I think that's what it was called) antenna mounted on the inside of the back cover. Thanks.
::Paul
